Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: Anyone a hydraulic genius
  1. #11
    4 Star General dmetalmiki's Avatar
    Join Date
    Aug 2006
    London England
    Posts
    4,586
    Thanks
    592
    Default
    AS mentioned previously, Check the routing of the pipes.
    Also, There are relief valves in the circuit, Check if they need servicing, As they may be 'blowing off' prematurely.
    And I just had a thought...Check the selector levers as they may well not be functioning properly.
    If a selector is not closing properly that would cause immediate loss of pressure, And could? let the oil bypass to where it should not. > Hence the two operations' working simultaneously<,
    And perhaps? is the cause of the failure to lift properly.
    If you can, And if possible, Have someone to check all pressures at the operating points.
    DIAMOND T M20.
    M54A2 I.H. M62. wrecker
    M54A2 5 Ton (with Praga command station surveillance body fitted)
    M45 530C TFFT fire truck
    1942 Ford Jeep (with underfloor tulsa winch)
    1945 Willys Jeep (with V8 flathead Engine) And overdrive.
    Packard Staff car. (WW11. General Pattern Tribute).
    Ural Military Motorcycle.
    Ex Army Hyster 4 ton Fork lift.
    Onan 7.5 kw ex army generator.
  2. #12
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    3,999
    Thanks
    2,813
    Default
    Quote Originally Posted by wheelspinner View Post
    Attachment 778443
    Ken, I have the entire air, electrical and hydraulics schematics combined into a single file. I'm going to try and upload them
    Edit: The whole file was 33 M and too big to upload, so I culled it down to just the two pages on the Wrecker Hydraulics
    One can send really large files for free with google. It is called google drive. You and the reciepiant must have google but that is only limitation I have seen.
    I have google so just send the entire 33mb to frank800man@gmail.com as a mail attachment.
    These files should be in SS database.
    Frank
    I was here, had a good time.
  3. #13
    4 Star General Coffey1's Avatar
    Join Date
    Sep 2012
    Gray Court SC
    Posts
    3,596
    Thanks
    476
    Default
    Got it to pick up rear but won't pick front up.
    Member of peanut gallery
  4. #14
    General
    Join Date
    Aug 2018
    Port angeles wa
    Posts
    438
    Thanks
    46
    Default
    Are the control valves rotary(valve core rotates) or push/pull(core slides in or out) spool type? Push pull spool type usually have o-rings at the ends and close tolerances inside, so they always work, but can leak at the ends.
    Rotary type often have o-rings dividing the halves of the valves so can leak across from one circuit to the other.
    Don't have a drawing but it sounds like you might have a leaking relief valve. But what could also be happening is you are loosing pressure from one side across to the other thru that selector valve as soon as you load up the system. The both circuits working regardless of selector position description is another clue. That or it was disassembled/de-installed in the past and not reconnected/re-assembled correctly...
  5. The Following User Says Thank You to Ronmar For This Useful Post:
    8madjack (10-06-2019)
  6. #15
    Join Date
    Sep 2012
    Gray Court SC
    Posts
    3,596
    Thanks
    476
    Default
    The winches are bad to the bone, pulled these big rocks from behind my house. Monday I'll load them up with crane and put them somewhere useful.
  7. #16
    Join Date
    Sep 2012
    Gray Court SC
    Posts
    3,596
    Thanks
    476
    Default
    The lines would have to be crossed somewhere upstream because there's absolutely no way to get them wrong at selector valves.
    They are large hard lines.
  8. #17
    4 Star General Floridianson's Avatar
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    6,060
    Thanks
    2,873
    Default
    How bout internal leakeage in the ram it's self?
    Some Men tell the truth. Some Men seek the truth. Some Men fear the truth but I pity the man the does not want to know the truth.
    James
  9. #18
    General
    Join Date
    Aug 2018
    Port angeles wa
    Posts
    438
    Thanks
    46
    Default
    Yea, could also be a bad ram seal, but the selector not cleanly separating the two operations I think may be a big clue...
    Duh, I have had a similar issue on a different type system. Have you tried loading up both systems simultaneously? IE: Try and lift the front of the LMTV that you cannot get off the ground, and while doing that try and operate a crane function that is already maxed out, like boom down when the boom is already against its down stop. Powering to an end stop usually causes pressure to build to maximum and open the relief valve.
    Pressure = force like to lift the truck, Flow rate = the speed at which it happens. If fluid is escaping from the wrecker side thru a bad control valve seal into the crane side when you put the wrecker under load, it cannot build enough pressure to perform the work/lift to full capacity.
    If while trying to lift the truck with the wrecker, you simultaneously try to build pressure on the crane side where fluid is escaping to, the wrecker side will also build pressure as the escape path is now blocked/restricted. If the wrecker lifts when you do this, the selector valve is most definitely leaking past...
  10. The Following 3 Users Say Thank You to Ronmar For This Useful Post:
    8madjack (10-06-2019), SCSG-G4 (10-08-2019), tennmogger (10-06-2019)
  11. #19
    Join Date
    Sep 2012
    Gray Court SC
    Posts
    3,596
    Thanks
    476
    Default
  12. #20
    Join Date
    Sep 2012
    Gray Court SC
    Posts
    3,596
    Thanks
    476
    Default
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
