Lonnie
- 18
- 18
- Pittsburgh, PA
If I understand correctly the fuel button controls your fuel pressure, but the fuel screw can change the flow/pressure also... I was trying to follow the circuits, but detailed really info is hard to come by.
Am i understanding it correctly that the screw in the throttle shaft can allow more pressure to the injectors, but it is ultimately limited to what the button will give for max pressure?
Will the screw allow you to fatten up the pressure in the mid RPM better than adding a smaller # button which ultimately boosts pressure across the board?
Trying to understand how the 2 in combination work together.... if they did the exact same thing, there would only be a need for 1 adjustment.
