Results 1 to 1 of 1
Thread: 2- M817s and 2- M929s for sale
  1. #1
    I'm the dude, man! Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,545
    108
    Default 2- M817s and 2- M929s for sale
    Multiple trucks for sale.
    817 with winch . Runs and drives. Brakes work just fine. Winch works as well. Body dumps as designed. Tires in good shape. Hard top. NHC250/5spd shows 2256 hours/54437 miles. $6600
    817 without winch. Runs and drives. Brakes work. Body dumps as desifned. Hard top. Tires are in great shape. NHC250/5spd with 2411 hours and 61566 miles.showing. $6000
    Or buy both 817s together for $11,000
    M929A0 [green] - NHC250, Allison Automatic. Showing 1909 hours and 40,000 miles. Nice G177 tires without spare. Bed operates as designed. Hard top installed. Truck has a broken bellhousing on the motor. Transmission bellhousing is fine. Was cracked due to a bad jackshaft joint that caused the bellhousing bolts to back out. Replacement bellhousing comes with the truck. $13,500 as it sits or $15,000 with the bellhousing replaced.
    M929A1 (tan) - NHC250, Allison Automatic, showing 1150hours and 31,000 miles. Hard top. Goodyear AT2 14.00s with no spare. Bed operates as designed. Truck is operated daily. Regular maintenance. Body is in great shape. No known problems. $18,500.
    All trucks have titles.
    817s and Tan M929A1 are located in Biloxi, MS
    Green M929A0 is located in Memphis.
    Shipping can be arranged just message me for a quote.
    Attached Images Attached Images
    2008 F-250 6.4L Powerstroke
    1979 AM General M920
    1984 AM General M915A1 (Big Cam III, HT3B Turbo, Brushless 24v Alternator with equalizer, A/C, Rear 20,000lb winch. 11R24 rear tires and 395s up front.)
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  2. The Following 3 Users Say Thank You to simp5782 For This Useful Post:
    M1078MAN (10-15-2019), rockman (10-22-2019), TNriverjet (10-21-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
