Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Generator removal question
  1. #1
    Private
    Join Date
    Oct 2019
    Susanville CA.
    Posts
    13
    Thanks
    Default Generator removal question
    Do I have to remove the whole front fender to get my generator out? Even with the panel above the fender removed,I can't access the two inner nuts on the bottom mounting bolts. Can't get to them underneath either because of the shield/splash guard. Am I missing something simple? One would think for service in the field, they would have made these items simple to get at, or folks had little tiny hands back in the 50's.
  2. #2
    Colonel
    Join Date
    Jan 2015
    phoenix,az
    Posts
    320
    Thanks
    19
    Default
    Offset box wrenches and sockets. The sucker is REALLY heavy. Be careful.
    1962 DON DJ3A
    1953 M37
    1950 M38
  3. #3
    Private
    Join Date
    Oct 2019
    Susanville CA.
    Posts
    13
    Thanks
    Default
    Yeah it looks heavy. Got the test adapters today, thanks again. I'm going to run a test on the genny tonight and keep my fingers crossed. I pulled the voltage regulator yesterday and cleaned the contact points and ground cables. After pulling the cover off the VR, it smelled like it had been smoked but put it back on and re polarized the generator, and still no charge. THE CIRCUIT BREAKER POINTS ON THE VOLTAGE REGULATOR don't even close.
  4. #4
    Private
    Join Date
    Oct 2019
    Susanville CA.
    Posts
    13
    Thanks
    Default
    Generator putting out 0.00 on the multimeter. Guess its toast. Looks like I'll be having that rebuilt plus a new solid state voltage regulator $$$$. I would like to talk to the previous owner and find out what he did to kill the charging system on this truck. He told me when I purchased it that it was in good working order after the restoration but had quit charging one day while he was driving it.
  5. #5
    4 Star General NDT's Avatar
    Join Date
    Dec 2008
    Camp Wood/LC, TX
    MVPA
    4954
    Posts
    7,402
    Thanks
    2,166
    Default
    Check the filter capacitor at the bottom of the regulator, maybe it has no continuity. They are old.
  6. The Following User Says Thank You to NDT For This Useful Post:
    cucvmule (10-28-2019)
  7. #6
    Colonel
    Join Date
    Jan 2015
    phoenix,az
    Posts
    320
    Thanks
    19
    Default
    You have the adapter. Full field the generator and see if it doesn't come to life. Follow the procedure in the TM.
    Then check the brushes. The genny is pretty bulletproof.
    1962 DON DJ3A
    1953 M37
    1950 M38
  8. #7
    Private
    Join Date
    Oct 2019
    Susanville CA.
    Posts
    13
    Thanks
    Default
    Quote Originally Posted by just me View Post
    ?? Full fielding? I did polarize the generator per the TM and nothing. I didn't see anything "full field'. Is this the same thing.
  9. #8
    Big wheeler cat peeler Valley Rock's Avatar
    Join Date
    Aug 2018
    Rogue Valley OR
    Posts
    131
    Thanks
    175
    Default
    It's very durable as stated and basic, open it up to see the brushes and inspect, they are likely the cause, if not just keep looking, a problem with them is often easily seen .
    1952 GMC XM211 Water Truck (For Sale)
    1963 Studebaker M50 Water Truck
    1991 BMY M931A2 Tractor currently being converted to water truck
  10. The Following User Says Thank You to Valley Rock For This Useful Post:
  11. #9
    Colonel
    Join Date
    Jan 2015
    phoenix,az
    Posts
    320
    Thanks
    19
    Default
    Edit.
    I need to check the manual to see if it is A circuit or B circuit to tell you how to full field.
    1962 DON DJ3A
    1953 M37
    1950 M38
  12. #10
    Colonel
    Join Date
    Jan 2015
    phoenix,az
    Posts
    320
    Thanks
    19
    Default
    Follow procedure on page 2-40 of the TM.
    Here is a link to the manual if you haven't found it already.
    https://www.steelsoldiers.com/showth...-s-for-the-M37
    You need TM9-2320-212-20 for these tests.
    1962 DON DJ3A
    1953 M37
    1950 M38
  13. The Following 2 Users Say Thank You to just me For This Useful Post:
    CMPPhil (10-23-2019), cucvmule (10-28-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
