Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: M416 Rear Light Assembly/Mounting Bracket
  1. #1
    Colonel 90Jimmy's Avatar
    Join Date
    Jan 2018
    Southern Illinois
    Posts
    233
    Thanks
    70
    Default M416 Rear Light Assembly/Mounting Bracket
    In need of a light assembly to include the mount that attaches the light to the left rear of trailer.
    Thank You
    1989 M998
    1986 M1009
    1986 M1009
    **** M416
  2. #2
    4 Star General cucvrus's Avatar
    Join Date
    Dec 2012
    Jonestown Pennsylvania
    Posts
    7,871
    Thanks
    2,573
    Default
    What does that bracket look like? Asking because I might have one attached to a light. Maybe.
    To argue with a person who has renounced the use of reason is like administering medicine to the dead. Thomas Paine: Founding Father Quote.
  3. #3
    Join Date
    Jan 2018
    Southern Illinois
    Posts
    233
    Thanks
    70
    Default
    240ED723-DA25-4027-90EB-E1A182102B68.jpgItem #23 in this illustration.
    1989 M998
    1986 M1009
    1986 M1009
    **** M416
  4. #4
    Join Date
    Dec 2012
    Posts
    7,871
    Thanks
    2,573
    Default
    Maybe. Is right and left the same?
  5. #5
    Join Date
    Jan 2018
    Southern Illinois
    Posts
    233
    Thanks
    70
    Default
    I’m not in town go look at the trailer, I think the mount can just be flipped over and used on either side.
    1989 M998
    1986 M1009
    1986 M1009
    **** M416
  6. The Following User Says Thank You to 90Jimmy For This Useful Post:
    cucvrus (10-28-2019)
  7. #6
    Join Date
    Dec 2012
    Posts
    7,871
    Thanks
    2,573
    Default
    DSCF6595.jpgThis is on a trailer frame I have outside. I have some lights that have brackets. I think this was an M101 trailer.
  8. #7
    Join Date
    Jan 2018
    Southern Illinois
    Posts
    233
    Thanks
    70
    Default
    I’m not sure if that would work or not. Thank you sir for the effort, thinking it may be easier to just fabricate the part.
    If you happen to have an M1009 seat bottom tucked away in that loft, I could use that.
    1989 M998
    1986 M1009
    1986 M1009
    **** M416
  9. #8
    Join Date
    Dec 2012
    Posts
    7,871
    Thanks
    2,573
    Default
    What side on the seat bottom? Must the fabric/vinyl be good? I still have a few taillamps I removed from M416 trailers. I want to look if they have a bracket.
  10. #9
    4 Star General M813rc's Avatar
    Join Date
    Oct 2006
    Near Austin, Texas
    MVPA
    28428
    Posts
    3,378
    Thanks
    6,690
    Default
    There are two types of light bracket for the M416, one for the small tail lights, another for the big ones. The one for the larger lights, obviously has a longer outer arm to clear the trailer and lift the light up a bit more.
    My trailer has the larger lights, but the short brackets, with spacers between the base and the trailer. Looks a bit odd to me. If I ever find a set of the longer arms (I tried a few years ago, with no luck), I'll give the shorter ones to someone who needs them.
    Cheers
    Rory
    M813A1 (USMC)
    V100 (M706) Armoured Car
    XM704 Armoured Car
    S404 Unimog (Swiss)
    M185A3
    M109A3
    M1009 (x2)
    M931A2 (x2)
    M715 (x2.5)
    M725
    M35A2 w/w
    M1030B1 (USMC) (x2)
    M274A5 Mule (USMC)
    M1028A2
    Austin Champ
    M270A1
    M1082 (x2)
    M146
    M116A3 HSTRU
    M1102 CMT-F
    M128A2C
    M129A4
    ADC-TSS-5
    M348A2C AN/MSC-25
    and some more stuff...
  11. #10
    Join Date
    Dec 2012
    Posts
    7,871
    Thanks
    2,573
    Default
    Do the M101 brackets look like something you need? They had the bigger lamps.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
