Results 1 to 5 of 5
Thread: help with m813 exhaust
  1. #1
    Private
    Join Date
    Nov 2019
    pennsboro west virginia
    Posts
    Thanks
    Default help with m813 exhaust
    can anyone help with my exhaust on my M813 non turbo? the muffler had rust through under the clamp that goes around it , and a hole in the elbow where it comes up through the finder. so i was going to patch the muffler by either welding it or using patch materal, but i was thinking of doing away with the muffler and using stainless flex pipe and re doing my battery compartment and runnung exhaust like the 900 series, has anyone done this or can give me advice so i dont jack up something or cause my self some more money, ?
  2. #2
    General Ajax MD's Avatar
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    527
    Thanks
    169
    Default
    You're talking about eliminating the muffler altogether then? These trucks are LOUD already. I definitely wouldn't drive it without hearing protection if you do.
    The output flange on my muffler has broken off. I'll be replacing the muffler and sticking with the stock configuration and that's still going to be pretty loud.
    Motorpool:
    (Isn't owning one of this insanity enough??)
    1971 M813 "Ox" (named for Dewey Oxburger)
  3. #3
    I'm the dude, man! Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,620
    Thanks
    108
    2008 F-250 6.4L Powerstroke
    1979 AM General M920
    1984 AM General M915A1 (Big Cam III, HT3B Turbo, Brushless 24v Alternator with equalizer, A/C, Rear 20,000lb winch. 11R24 rear tires and 395s up front.)
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  4. #4
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    527
    Thanks
    169
    Default
    At least there's a muffler in that configuration. Your neighbors and ears will thank you.
    Motorpool:
  5. #5
    4 Star General /Moderator doghead's Avatar
    Join Date
    Jan 2006
    NY
    MVPA
    8675309
    Posts
    26,027
    Thanks
    2,542
    Default
    New muffler, $250
    New lower J pipe, $150
    New upper stack, $50
    Gasket, $12
    All readily available.
    M817, M818, M819, M35A2 w/w, M35A2, M109, M105, M116A2, M101A2, Pioneer tool trailer, MEP-002, MEP-017A, 5ton winch shear pins, Oral-B toothbrush
    Ah Beefco Industries Northeast marketing associate
    Don't judge a fish by its ability to climb a tree
    https://www.youtube.com/watch?time_continue=12&v=T6BTcEwtmZo
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
