Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Alternator Charging issue
  1. #21
    2 Star General Reworked LMTV's Avatar
    Join Date
    Nov 2016
    TN
    Posts
    610
    Thanks
    352
    Default
    Your cables are likely original. You may want to consider replacing these. I learned recently that, while the connector your bolt on with looks fine, underneath you can have destroyed wire where the connector meets the wire. I learned this when I cut through a connector with a cut off wheel. Had I not done this, i would have assumed everything was ok, when in fact this would likely cause a voltage drop / resistance. The problem with wire that age is that moisture wicks up and destroys the silver or zinc coating. Electrolysis does not help either. This leaves the copper to oxidize and turn a very dull color. Now the connection from the connector to the wire is shot. You can't wire brush it either.
    No doubt that this is thick wire, but since the runs are really short, it should not cost that much. The connectors can be had on Amazon. You will need the hammer crimper, but they are cheap.
    Quote Originally Posted by DigDirt View Post
    I am pretty sure that it is wired correctly in that I labelled the wires before I relocated the box. That said, I have wired it opposite to what it is now to ensure completeness and the engine wouldn't start..,Attachment 782828
    I will make a temp jumper from the 24v on the polarity box to the ENG terminal this weekend. That is a great suggestion! Thanks.
    1998 M1088A0 former KY National Guard vehicle
    Many states have banned on road use of MV's. Even Canada has made driving them difficult. In a flash all of your work money and work is wasted. Watch your State Legislator closely! This can be done by setting up an automatic send of all State Bill proposals. Once it's law, it's hard to get it changed.
  2. #22
    Private
    Join Date
    Jun 2019
    Phoenix, AZ
    Posts
    15
    Thanks
    Default
    Quote Originally Posted by Reworked LMTV View Post
    You make a great point! The alternator cables to the reverse polarity box are the only ones that I haven't changed out yet and I did reroute them when I changed the location of the reverse polarity box. I'll give that a whirl tomorrow. All that said, the regulator still comes up bad during trouble shooting...ie: voltage to the exciter wire but not to the regulator. At the very least I've changed out 20+ year cables
  3. #23
    Private
    Join Date
    Jun 2019
    Phoenix, AZ
    Posts
    15
    Thanks
    Default
    Update: changed out the alternator and voltage regulator and batteries are charging properly again. Gotta say the voltage regulator going out right after I changed the location of the reverse polarity box, is a conundrum... coincidence or cause?? Even though the troubleshooting was a PITA, it lead to the cause even in spite of me not trusting the DX! I learned a lot and now have all new cables . I appreciate everyone's help and input.
  4. The Following User Says Thank You to DigDirt For This Useful Post:
    coachgeo (11-30-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
