Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 10 of 44
Thread: Oil / Gas mix to fuel deuce
  1. #1
    Colonel TommyG45's Avatar
    Join Date
    Jan 2007
    Cleveland Ohio
    Posts
    210
    Thanks
    Default Oil / Gas mix to fuel deuce
    Hey all,
    I have read plenty of posts where individuals are mixing gas and used motor oil. Has anyone ever used Synthetic oil in the mixture? My Deuce just arrived last night, and I have been collecting used motor oil, but I have no idea if any of it is Synthetic oil.
    Does it matter?
    I will be cleaning the oil with the centrifuge from diesel craft.... I though I would ask the question as it came up today at work.
    Any suggestions?
    TommyG
    Pics of the new Deuce attached
    Attached Images Attached Images
  2. #2
    4 Star General emr's Avatar
    Join Date
    Jun 2006
    landing , new jersey
    Posts
    3,212
    Thanks
    1,706
    Default RE: Oil / Gas mix to fuel deuce
    It can not make a difference, and if U are ever in need mix the oil in use, they are compatable, it was not true in the past about it not being able to be mixed in the engine.and as in any case, ANY oil is better than NO oil.But as for burning it , its fine...Randy
  3. #3
    Join Date
    Jan 2007
    Cleveland Ohio
    Posts
    210
    Thanks
    Default
    Randy,
    Thanks a bunch, I will keep collecting without worry.
    TG
  4. #4
    Banned
    Join Date
    Jul 2007
    TN
    Posts
    1,496
    Thanks
    24
    Default
    Ah my last addition to the tank a about 5 gallons of synthetic from my other truck ( some i had saved plus a new change ) doesnt seem to hurt it. Theres a slight bit of blue smoke from the exhaust goin down the road and you can smell the oil a bit but it beats paying $4.30 a gallon for straight #2. I just mix mine a lil here and a lil there 50/50 gas/umo no probs it looks funny in the lines and make sure you got filters on hand just in case. I was worried at first about the oil seperating in the tank but it doesnt seem to be a issue. Now I just add it and go. Good luck, Captain
  5. The Following User Says Thank You to Alredneck For This Useful Post:
    SSGHillbilly (10-13-2019)
  6. #5
    4 Star General
    Join Date
    Apr 2006
    Posts
    1,137
    Thanks
    Default
    Synthetic oil is the same as regular oil. The only difference being that synthetic oil is more refined to be of similar desired oil molecules. It all burns the same. The real synthetic oil that was made for jet engines and such is not very common these days. The government dilluted the name to include just more refined oil years back. Anyways I never heard of any problems burning the real synthetic oil either.
  7. The Following User Says Thank You to builder77 For This Useful Post:
  8. #6
    General wiggall's Avatar
    Join Date
    Jun 2008
    Lenore, Id.
    Posts
    563
    Thanks
    89
    Default
    I am getting a 1968 Kaiser-Jeep with the mulitfuel engine. Has anyont tried the ( Diesel Secret Energy- Alternative Biofuel ) system? If so I would like to know how it worked.
    FTG2 Wiggles USS EDSON DD 946 1969-1973
    1968 Kaiser-Jeep M35A2 W/W AKA BEAUTIFUL BEAST
  9. #7
    Colonel chuck500cc's Avatar
    Join Date
    Oct 2007
    DFW Area
    Posts
    310
    Thanks
    Default
    50/50 umo and deisel. truck loves it.
    Chuck XD Fan
  10. #8
    General offroaddiesel's Avatar
    Join Date
    Dec 2007
    western maine
    Posts
    409
    Thanks
    Default
    dont mean to sound negitive, maybe iam a little nervous,but i have to ask. just how are you filtering umo. i have been reading alot on people using it and right now the cons out weight the pros.i have many gallons here but still not convinced its the right thing.so please enlighted me,diesel fuel is over 5 a gallon here.for the people using umo, how long have you been using it .and what ratio. a 50/50 seems a little high to me. thanks steve
  11. The Following User Says Thank You to offroaddiesel For This Useful Post:
  12. #9
    General roger-wilco-66's Avatar
    Join Date
    May 2005
    Karlsruhe, Germany
    Posts
    598
    Thanks
    151
    Default
    Joseph,
    do the speaker magnets actually pick something up in the tank? Would be interesting to know if they can attract very small ferrous objects in the oil. The larger ones are filtered out anyhow.
    Another thing that makes me think is what if you dilute the wmo / umo with diesel or gas before letting it sit for a while or filtering it - wouldn't the crap settle more easily or the filtering process be faster because of the lower viscosity?
    Mark
    in dubio, pro reo!
    roger-wilco-66 aka Mark
    1966 M35a2 w/w whistler turbo
  13. #10
    4 Star General devilman96's Avatar
    Join Date
    Mar 2006
    Boca Raton, FL
    Posts
    2,061
    Thanks
    Default
    Filter filter and then filter again... I run 80/20 synthetic (80 is oil).... Get a bypass filter assy from napa and pump it through at a low PSI... This will get you down to about 5M... I do this 2X once pumping into my collection tank and then while pumping out into my trucks...
    Oil sampling on your engine oil will tell you if your causing yourself problems or not...
  14. The Following User Says Thank You to devilman96 For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
