Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 51 to 60 of 60
Thread: Picked up a sand blaster
  1. #51
    Sergeant
    Join Date
    Mar 2008
    Berea, KY
    Posts
    Thanks
    Default
    Couple of things...forget about soda. I think that was just a fad. Everyone I have talked to who had something soda blasted says it was a mess and they would never do it again. Right now, it looks like the trend is to go lots of media volume with a lower psi. I spoke at length to a place doing whole car bodies using black magic using the high volume lower psi route and they say they can sandblast a whole car body without warping. Now these military trucks will take more abuse. They might hold up to any psi and volume from anything but it might be best to go the high volume lower psi route too. I'll see if I can dig a link up to that place. If you can , recycle the black sand. It only gets better with age. I'd suggest blasting inside a shipping container.
  2. #52
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    Thanks
    2,442
    Default
    Quote Originally Posted by gimpyrobb View Post
    So I ended up grabbing a Joy air compressor, 150 cfm for cheap. It has an International Harvester slant 4 motor to power the comp. Anyone know anything about these motors to check BEFORE I try to fire it up? It is in poor condition, but I will try to bring her up to "full mission capable" status. One step closer to having a blasting trailer!
    Well 2 days ago I tried to turn it over and the motor locked up on me. I pulled the plugs and shot some atf in the cyls. I was busy yesterday so today I went over and tried to start it again. No luck. I pulled the compressor section off the motor and figured out how to turn the flywheel in reverse. Once that was accomplished, I hooked up some jumper cables and she turned over and over and over! Woohoo, free spinning motor. Next I cleaned the plugs with a wire brush and installed the wires. Sprayed some starter fluid in the carb and hit the button. Motor turned over but didn't fire. Check for spark, no spark! I tested the coil, it had no juice supplied to it. Jumped a wire from the coil+ to the jumper cables, sprayed some starter fluid, hit the starter button and she fired up!. Now I have to find that coil wire and fix it right, then hook up a fuel tank and plumb it in. Once the motor runs for a few min. I will go ahead and hook up the compressor part. Things are looking good for a cheap GOOD blasting settup.
    Don't worry about the size difference
  3. #53
    Blind squirrel rehabiltator Speddmon's Avatar
    Join Date
    Apr 2009
    Cambridge, Ohio
    Posts
    4,678
    Thanks
    347
    Default
    sounds like you are making good progress on the compressor. A running motor is always a good thing to have!!
    Quote Originally Posted by Recovry4x4 View Post
    That's why I knew the answer and you didn't. I read the kindling.
    He is "anti-doghead".
    Even a blind squirrel finds an acorn every now and then!
    1970 M35A2 "The Stone Wagon" SOLD
    1985 M1028/M1031 w/700R4 "Road Oiler"
    MEP-003a 3000 hrs
    MEP-003a 1500 hrs
    1964 Case 530CK "Construction King" Backhoe/loader "Yard Oiler"
    MEP-002a & MEP-003a Spin-on oil filter kits are still 4 sale in the classified section
  4. #54
    4 Star General Nonotagain's Avatar
    Join Date
    Jan 2009
    Parkville, MD
    Posts
    1,446
    Thanks
    55
    Default
    Gimpy,
    The International motor probably is a 196 cu in 4 banger. I had one in a old International Scout 800A.
    They use the same crank, connecting rods, cylinder head and pistons as the 392 V-8 engine. Just about all of the International gasoline engines shared some parts.
    If memory serves me, there should be a plate running the length of the block where they sawed the other half of the block off..
  5. #55
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    Thanks
    2,442
  6. #56
    Join Date
    Jan 2009
    Parkville, MD
    Posts
    1,446
    Thanks
    55
    Default
    Yep, that's it.
    All of the internal engine parts and the cylinder head should be the same as a 392 V-8.
  7. #57
    General
    Join Date
    Feb 2009
    Keesler Air force base/ MS
    Posts
    417
    Thanks
    Default
    The 152ci IH motor is half of a 304ci IH motor.
    The 196ci IH motor is half of a 392ci IH motor.
    The 345ci is most common though.
    Try a scout forum for info on the engine.
    http://www.binderplanet.com/
  8. #58
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    Thanks
    2,442
    Default
    Thanks for the link, I got it running with help from the guys at Binderbench.com. Just needs some fine tuning.
  9. #59
    Private 1190KTM's Avatar
    Join Date
    Dec 2016
    Chandler, Oklahoma
    Posts
    Thanks
    Default
    So is there more to this saga? I'd like to see a progress report!!
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  10. The Following User Says Thank You to 1190KTM For This Useful Post:
    98G (01-05-2017)
  11. #60
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    Thanks
    2,442
    Default
    Not really, I took everything to Stretch's place and there it stits waiting for use.
  12. The Following User Says Thank You to gimpyrobb For This Useful Post:
    98G (01-05-2017)
Similar Threads
  1. Picked up a M103A3 - For my MEP002
    By OD_Coyote in forum Trailers
    Last Post: 11-02-2008, 16:51
  2. Need item picked up at Ft. Lewis
    By steelsoldiers in forum Need item inspection or loadout?!
    Last Post: 09-10-2008, 12:52
  3. picked up Deuce
    By uh60 in forum The Deuce
    Last Post: 07-08-2008, 00:29
  4. Picked up a M37, getting redy to paint!
    By donkdonk in forum M37
    Last Post: 12-14-2007, 21:43
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
