Page 13 of 13 FirstFirst ... 3 9 10 11 12 13
Results 121 to 124 of 124
Thread: Towing a M105a2 w/ civilian Pick Up ?
  1. #121
    General
    Join Date
    Jul 2006
    Southern, Maryland
    Posts
    448
    Thanks
    96
    Default
    When Slate revived this thread, his question was about recovering an empty trailer with a pickup. There seems to be a some “incorrect” knowledge on this topic going around. An empty M105 weighs 2750 lbs. Trailer brakes are only required for trailers that weigh over 3000 lbs. My suggestion was to use a lifted hitch to have the trailer ride more level. I don’t have a picture of my setup; however, this is an image of the kind that I use. It is rated for 10,000 lbs. One of the reasons for having a hitch that is close to the level of the pintle hook is for coupling. It is a lot safer when the pintle hook and pintle ring are similar in height and one isn’t trying to horse the thing around. I have safely recovered quite a few M105s with a 1-ton pickup instead of taking a 5-ton cargo truck to save fuel costs. The most important thing to remember is to operate the vehicle appropriately to what one is driving.
  2. The Following 4 Users Say Thank You to Scrounger For This Useful Post:
    SCSG-G4 (07-17-2019), Slate (07-16-2019), tobyS (07-16-2019), USAFSS-ColdWarrior (07-16-2019)
  3. #122
    4 Star General tobyS's Avatar
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    4,119
    Thanks
    2,585
    Default
    Learned something. I thought it was single axle exempt, but the weight limit in Indiana is also 3000# to be exempt. The spec I have says they weigh 2650#.
    M35A3 4x4 "Money Pit"
    M929A2
    (14) 5 tons bought and sold
  4. The Following 2 Users Say Thank You to tobyS For This Useful Post:
    Slate (07-16-2019), USAFSS-ColdWarrior (07-16-2019)
  5. #123
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    9,001
    Thanks
    6,081
    Default
    Quote Originally Posted by Scrounger View Post
    In michigan anything with a GVW of #3000 or above needs brakes , they don't care about empty weight.
  6. The Following 2 Users Say Thank You to porkysplace For This Useful Post:
  7. #124
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    4,119
    Thanks
    2,585
    Default
    Quote Originally Posted by porkysplace View Post
    So you are saying that in Michigan they can arrest or cite you for being over and not having brakes without ever getting out a scale, ...all done from the tag?
    We learn something new every day.
    M929A2
  8. The Following 4 Users Say Thank You to tobyS For This Useful Post:
    Scrounger (07-16-2019), SCSG-G4 (07-17-2019), Slate (07-16-2019), USAFSS-ColdWarrior (07-16-2019)
Similar Threads
  1. My towing light setup MV's/Civi
    By Stretch44875 in forum Deuce Modification and Hot-Rodding
    Last Post: 09-27-2017, 17:48
  2. Towing 2 m105a2 trailers?
    By reb87 in forum Trailers
    Last Post: 04-11-2010, 16:02
  3. Towing recommendations between Barstow and Riverside, CA
    By nf6x in forum Transportation Needs
    Last Post: 09-17-2008, 22:10
  4. M105A2 Trailer Pick Up*** NOW WITH PICS***
    By mtnpatriot in forum Trailers
    Last Post: 08-20-2008, 08:32
  5. Will a M101 fit inside a M105A2??
    By 70deuce in forum Trailers
    Last Post: 01-21-2008, 15:28
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
