Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: Peter Bog's CAD deuce schematic!
  1. #21
    Colonel Wolfgang the Gray's Avatar
    Join Date
    Mar 2016
    New River, AZ
    MVPA
    37931E
    Posts
    308
    1,556
    Default
    Quote Originally Posted by mudguppy View Post
    ok, so i downloaded the cad drawings and made a few of the recommended changes:
    starter - flipped coil and contacts
    added circuit breaker to light switch
    changed color to green
    renamed "Switch Ignition" as "Master Switch"
    changed heater feed "35" to read "55"
    attached is the PDF version. aaaaaaannnnd i'm having trouble getting the .dwg uploaded, even zipped as a .zip file.
    what's the secret?
    Thanks, this is Awesome!
    As a group of soldiers stood in formation at an Army Base, the Drill Sergeant said, "All right! All you idiots fall out."
    As the rest of the squad wandered away, one soldier remained at attention.
    The Drill Instructor walked over until he was eye-to-eye with him, and then raised a single eyebrow.
    The soldier smiled and said, "Sure was a lot of 'em, huh, sir?"
    1969 Kaiser Jeep M35A2
    2016 Polaris Sportsman 570
    2008 Ural Gear-Up
    1991 Jeep Wrangler (355,000 + miles)
  2. #22
    Private
    Join Date
    Jan 2018
    Soldotna Alaska
    Posts
    Default
    Everyone says. Your question has been covered a thousand times. Do your research instead of asking the same question again. Iíve been researching for two days. Why can I not find the file and see this schematic. Am I missing something ?
  3. The Following User Says Thank You to bartsworld1982 For This Useful Post:
    USAFSS-ColdWarrior (10-28-2019)
  4. #23
    Chaplain USAFSS-ColdWarrior's Avatar
    Join Date
    Jun 2009
    Posts
    16,813
    60,016
    Default
    Quote Originally Posted by bartsworld1982 View Post
    Everyone says. Your question has been covered a thousand times. Do your research instead of asking the same question again. I’ve been researching for two days. Why can I not find the file and see this schematic. Am I missing something ?
    Post #2 of this thread contains two click-able links which will display the images you seek.
    By the way,
    WELCOME ABOARD Find a bunk, Stow your gear, and Prepare to get underway
  5. #24
    Senior Chief/Moderator hndrsonj's Avatar
    Join Date
    May 2004
    Cheyenne, WY
    MVPA
    31099
    Posts
    7,416
    997
    Default
    Quote Originally Posted by USAFSS-ColdWarrior View Post
    By the way,
    Actually post 16's link has the current upgrades.
    1951 Reo M48 Deuce Tractor
    1962 Dodge M37B1 w/w
    1951 Willys M38
  6. The Following User Says Thank You to hndrsonj For This Useful Post:
  7. #25
    Join Date
    Jun 2009
    Posts
    16,813
    60,016
    Default
    Quote Originally Posted by hndrsonj View Post
    OOPS
    Thank you.
Similar Threads
  1. It runs.. maybe not..
    By Crazyguyla in forum The Deuce
    Last Post: 03-24-2011, 13:11
  2. fun things in the deuce
    By ajg6989 in forum Deuce Modification and Hot-Rodding
    Last Post: 10-26-2009, 07:13
  3. What makes a deuce a deuce?
    By cranetruck in forum The Deuce
    Last Post: 04-20-2009, 12:43
  4. PCBowman's New Deuce
    By JDToumanian in forum The Deuce
    Last Post: 02-08-2007, 14:55
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
