Page 21 of 21 FirstFirst ... 11 17 18 19 20 21
Results 201 to 205 of 205
Thread: GL-1 Gear Oil Alternative
  1. #201
    4 Star General cattlerepairman's Avatar
    Join Date
    Jul 2007
    NORTH (Canada)
    MVPA
    37751E
    Posts
    1,940
    Thanks
    952
    Default
    Before we tear shreds off each other, perhaps it is worth asking whether there even exists the one right answer to the question asked about which gear oil is best for the Spicer 3053A transmission. It may well be that there are several options that are not easily distinguished being "better" or "worse".
    If there are, indeed, two or more options that can be valid, it creates nothing but churn and hard feelings if we continue to try to nail down "the right one". Thank you.
    MVPA member. 1974 M35A2C w/w "Queen Lola", rebuilt LDS-465-1A, "D" turbo, Waterloo Overdrive upgrade. Med towbar, 11.00R20 Goodyear G286, flipped hubs, remote brake fluid reservoir, spin-on filters, bypassed FDC, LED taillights, LED headlights, LED turn signals, WESTACH EGT/boost gauge, AVM lockout hubs, LED convoy light, LED lollipop lights, HMMWV seat on air ride base, M211 dash passenger grab handle, hood lift kit, 24V solargizer/battery minder, ether start kit, flasher module mod, heavy duty dog bone ends, M35A3 aluminium fuel tank.
  2. The Following 7 Users Say Thank You to cattlerepairman For This Useful Post:
    FloridaAKM (07-20-2019), Floridianson (07-15-2019), gringeltaube (07-15-2019), Menaces Nemesis (07-15-2019), silverstate55 (07-16-2019), Terracoma (07-22-2019), Tracer (07-16-2019)
  3. #202
    Colonel Slate's Avatar
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    238
    Thanks
    128
    Default
    I apologise if I reopened the can of worms thread. I for one appreciate All of the advice and info here. And understand every decision "I" make, about my truck is on me.
    Sent from my moto z3 using Tapatalk
  4. #203
    4 Star General rustystud's Avatar
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,137
    Thanks
    2,290
    Default
    Quote Originally Posted by cattlerepairman View Post
    I agree cattlerepairman. That is why I said I did not think running 80/90W oil is bad. I ran it for decades in my trucks and in trucks I serviced over the years. It was after the "great oil debate" that I finally changed my mind.
    (last sentence removed)
  5. The Following User Says Thank You to rustystud For This Useful Post:
    mobileauto2000 (07-17-2019)
  6. #204
    Sergeant Major Major Asstyrd's Avatar
    Join Date
    Mar 2010
    CA
    MVPA
    7404
    Posts
    191
    Thanks
    Default
    Dizzying thread. Back and forth like a jeep thread about which is better - GPW or MB.
    Not a truck experience, but I recently switched the 80w90 GL-4 in my jeep trans and TC and put GL-1 oil in it, marketed as Ford tractor transmission oil. Very inexpensive at Tractor Supply. Took it on a 80 mile road run of twisties, hills, 45 mph stretches. First impression was the synchros worked a little smoother, BUT I couldn't shift from neutral to first at one stop sign without rolling the jeep back a foot, and later it wouldn't go from second to third when driving which has never happened. Double clutching made it work and then went back to working when single clutching, so a random issue. My trans is old and pops out of second so I could have more serious trouble than oil issues. This and reading this thread got me thinking that two of the same models of trannys can be different enough inside so that a lube that works the best in one might not be great in the other.
    Military Vehicle Collectors of California
    1944 Willys MB
    1942 Ford GPW Special Air Service Replica
    1941 Indian 640
    BSA folding bicycles
  7. #205
    General Katavic918's Avatar
    Join Date
    Jul 2015
    Maryland
    Posts
    447
    Thanks
    126
    Default
    The reason I use gl-1 over gl-5 in my spicer transmission is because the manufacturer does not recommend the ep additives present in gl-5. These transmissions have had gl-5 in them for twenty years without any issues. That to me is proof enough that gl-5 is safe to use. Assuming yellow safe of course. But just to satisfy my OCD, I will continue to use gl-1 or straight weight 30,40 or 50.
    "I feel I was denied.....critical....need to know.....information"
    1970 M35A2 (Sold 8-26-17)
    1991 M998
    1972 M35A2
Similar Threads
  1. Speedometer Adapter Leaking Gear Oil
    By onegmjack in forum The Deuce
    Last Post: 12-09-2015, 00:01
  2. GL-1 gear oil
    By ken in forum The Deuce
    Last Post: 03-13-2012, 23:25
  3. On Bypass oil filters - to get the small particles
    By OPCOM in forum Deuce Modification and Hot-Rodding
    Last Post: 06-29-2009, 00:17
  4. Replies: 6
    Last Post: 10-15-2007, 07:38
  5. IF YOU NEED GEAR OIL
    By red devils dude in forum The Deuce
    Last Post: 01-27-2005, 22:46
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
