Page 18 of 21 FirstFirst ... 8 14 15 16 17 18 19 20 21 LastLast
Results 171 to 180 of 205
Thread: GL-1 Gear Oil Alternative
  1. #171
    4 Star General
    Join Date
    Aug 2009
    Maryland
    Posts
    1,701
    Thanks
    118
    Default
    Quote Originally Posted by Deuce007 View Post
    I am wanting to drain and refill my differentials in my a3 this winter but I have been wondering what brand of Gl-5 do you recommend? After some looking I have found this GearPlusŪ SAE 80W-90 GL-5 Gear Oil and Castrol HYPOY C 80w-90 Gear Oil | Product Details | Pep Boys but I would like to know if either of these will work or not. I would prefer using Super Tech 80W-90 High Performance Gear Oil, 1 Gallon: Automotive : Walmart.com because that would be the easiest to get because I could just go to my local walmart but I would appreciate any answers.
    I'm not at all fussy about what I use in the differentials. They are open differentials, so there is no need for funny stuff like with limit-slip. I am perfectly happy with the stuff that is blended up for tractor supply, and I would imagine the walmart, or pepboys oils would be fine too. Just be sure that it is really GL5 and you will be fine.
    -Chuck
  2. #172
    Sergeant Major Deuce007's Avatar
    Join Date
    Aug 2011
    North Dakota
    Posts
    138
    Thanks
    Default
    Quote Originally Posted by stumps View Post
    -Chuck
    OK thanks for the input. I will be heading to Walmart tomorrow so I will keep my eyes open for some GL5.
  3. #173
    Moderator m16ty's Avatar
    Join Date
    Mar 2007
    Dickson,TN
    Posts
    9,553
    Thanks
    983
    Default
    I don't get hung up on the high priced, big name fluids. The fact is, many of the brands come from the same place. I buy many NAPA branded fluids. I know their engine oils are Valvoline in a NAPA container for less price than the same Valvoline product.
    If you think about it, I know several people that are lazy with servicing their vehicles. They will go way,way past recommended service intervals and use the cheapest oils they can find. They tend to get thereabouts the same service life on components as I do. I try to follow recommended service intervals and use a decent fluid brand but I sometimes wonder if I'm wasting money.
    The only member that ever gave himself a infraction point.
    www.americanmachinerymoversinc.com
    1972 M35A2C dump w/w (nothing more than a hunk of scrap iron between two winches)
    1985 Mack RD822SX (Operation Desert Storm veteran)
    M1000 transporter
    1967 M715
    M101A2
    4- M105s
    M149A2 tanker trailer
    M49 parts truck
    M35A2 parts truck
    M936 (converted to lime spreader truck)
  4. #174
    Join Date
    Aug 2011
    North Dakota
    Posts
    138
    Thanks
    Default
    Yeah, I don't like to buy the most expensive oil because practically any new GL5 has to be better than whats in there already.
  5. #175
    4 Star General sandcobra164's Avatar
    Join Date
    Nov 2009
    Leesburg, GA
    Posts
    2,906
    Thanks
    160
    Default
    I'll keep the fire going. I just changed my trans and transfer case oil this weekend with Non Detergent 40W per M35Tom's recommendation. Guess what, I got about 3 gallons of old oil to burn in the tank. My transfer case is much quieter and my transmission no longer grinds going into 4th. I'll likely upgrade to the taller overdrive when it warms up, I do like the drop in temps in my gear boxes after swapping to 40W motor oil and I stand by M35Tom's advice. Less heat and less gear whine can't be bad for anything. I guess I could pour some Lucas in it!!!
    84 AM General M923 "General Non-Sense"
    85 Chevrolet M1028 CUCV "Sarge"
    05 Silver Eagle M1102 (Sarge's New 4 Wheeler Hauler)
    Gone but not forgotten....
    71 AM General M35A2 "Big Trucks"
    87 Pribbs Manufacturing M105A2
  6. The Following User Says Thank You to sandcobra164 For This Useful Post:
    Floridianson (07-15-2019)
  7. #176
    Sergeant Major Slate's Avatar
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    180
    Thanks
    82
    Default
    Lucas makes a synthetic Gl-1 50w transmission oil that is supposedly yellow metal safe. Has anyone else used this?
    Sent from my moto z3 using Tapatalk
  8. The Following User Says Thank You to Slate For This Useful Post:
  9. #177
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    180
    Thanks
    82
    Default
    Quote Originally Posted by Slate View Post
    Ok I read through the beginning Pat of this thread and holy stuff..... maybe I shouldn't have asked and now I am more confused than ever. I'll use something and I bet it will work.
  10. The Following User Says Thank You to Slate For This Useful Post:
  11. #178
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    3,610
    Thanks
    2,518
    Default
    The transmission and the transfer case have no pumps and work in fine fashion when the nasties are allowed to drop out of suspension.
    Don't get confused about it all.
    Just put straight 30 or 40 weight in it which will not cause problems and alleviate problems, hot or cold.
    Gee, did We beat this one all to death yet?
    post 286 in here and many other places too
    https://www.steelsoldiers.com/showth...a2-oils/page19
    If you just filled it with pee it would still work Ok for a while, but think about what it is. Think 55 Chevy gearbox.
    Gee, how many gears are you flat-shifting into?
    If you want it to last another 50 years than search around these forums,
    It is the BEST place..............................
    I was here, had a good time.
  12. #179
    2 Star General mobileauto2000's Avatar
    Join Date
    Jan 2011
    Springfield Or
    Posts
    710
    Thanks
    1,397
    Default
    When this thread was hot I eagerly awaited daily updates. Hard to believe it was so long ago.
    I run 50 weight motor oil in the trans and transfer case. The sincros started working better in a 100 miles or so. It was a daily driver back then. Now I look at it after work and it seems 50 feet tall so I drive the Lincoln home instead. Just part of gettin' old.
    Have a great week
    John
    Proverbs 16:7 When a man's ways please the LORD, He makes even his enemies to be at peace with him.
    http://www.steelsoldiers.com/showthr...-box-for-m35a2
  13. The Following User Says Thank You to mobileauto2000 For This Useful Post:
    frank8003 (07-12-2019)
  14. #180
    Join Date
    Nov 2009
    Leesburg, GA
    Posts
    2,906
    Thanks
    160
    Default
    When I posted in this thread I still had a Deuce! I did notice a positive difference when switching to Non-Detergent 40W oil in the trans and transfer. I used "Freds" cheap oil and the truck is still pulling peanut wagons just fine for the gentlemen I sold it to. I doubt he has changed it.
  15. The Following User Says Thank You to sandcobra164 For This Useful Post:
Similar Threads
  1. Speedometer Adapter Leaking Gear Oil
    By onegmjack in forum The Deuce
    Last Post: 12-09-2015, 00:01
  2. GL-1 gear oil
    By ken in forum The Deuce
    Last Post: 03-13-2012, 23:25
  3. On Bypass oil filters - to get the small particles
    By OPCOM in forum Deuce Modification and Hot-Rodding
    Last Post: 06-29-2009, 00:17
  4. Replies: 6
    Last Post: 10-15-2007, 07:38
  5. IF YOU NEED GEAR OIL
    By red devils dude in forum The Deuce
    Last Post: 01-27-2005, 22:46
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
