Page 17 of 17 FirstFirst ... 7 13 14 15 16 17
Results 161 to 168 of 168
Thread: Lifting a Bobbed Deuce
  1. #161
    4 Star General rustystud's Avatar
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,422
    2,374
    Default
    Quote Originally Posted by Shane 1971 M35A2 View Post
    I know this thread is on lifting bobbed Deuces, but are there any pictures and build ideas/methods on lifting a non-bobbed 3 axle M35A2 with 395's/46 inch tires that just barely fit on the rear tandems?
    There are several reasons not to do this. One front end stability, ie" steering issues. You can get away with a bit of funny business on the front axle, but too much and your steering geometry goes out the window. Real hard to correct it.
    Second and possibly the strongest reason not to lift is the rear floating suspension system. With the torque rods and the floating spring system you are looking at major surgery on the truck. The torque rods need to be extended first off, then the spring perch needs to be remounted. Not a small issue. Then even if you did "everything" correctly your looking at rear end stability issues. The center of gravity has risen well above safe standards. You can no longer "safely" scale hillsides or traverse gulley's without the constant fear of tipping over.
    But hey, it's your truck. Do what makes you happy !
  2. #162
    Private
    Join Date
    Mar 2017
    Travelers Rest. S.C.
    Posts
    Default
    Thanks for input on 3 Axle lifted M35A2. I am in the thinking it over phase, and if you could just lower the whole tandem rear assembly as a unit, and then use Black Rock Fab. front spring mounts, widen the stance with the super singles and then maybe power steering as a bonus, and not have any adverse effects... I think it would be a grand slam. Thanks again. Shane
  3. #163
    Join Date
    Sep 2011
    Posts
    8,422
    2,374
    Default
    Remember the torque rods also attach to the differential housing. If you try and move the whole rear assembly your messing with the driveline angles now to. It is a real complicated thing to consider.
  4. #164
    Private
    Join Date
    Mar 2017
    Posts
    Default Driveline Angles
    I know the driveshafts will be at steeper angles and can cause unwanted vibration especially the shorter front. Lockout hubs would take care of the front as the front driveshaft would not spin unless the locked in (both by air switch and the front hubs engaged), and vibration would not be much of an issue when crawling slow with the front engaged. Now for the rear which is quite a long driveshaft anyway, it might not vibrate with its normal U-joint, but if it did at road speed, I might could use a CV joint or "double cardan" U-joint right before the middle axle (basically two U-joints in series) like the lifted Jeep guys use to solve the steep driveshaft angle vibration problem. I know they also can tilt their one rear differential up more in line with the steeper driveshaft on an angle also, which I could not do with two tandem floating rear axles. Anyway I am just thinking, I know the can of worms when trying to modify something might be more squirmy than it is worth. Thank you.
    Shane
    Quote Originally Posted by rustystud View Post
  5. The Following User Says Thank You to Shane 1971 M35A2 For This Useful Post:
    rustystud (09-28-2019)
  6. #165
    Corporal Watsonpreston's Avatar
    Join Date
    Mar 2014
    Dallas
    Posts
    45
    15
    Default
    All of the above has already been done and all of the concerns below about drive shafts are some what not valid in the video below you can see how far stock drive shafts can go
    I have since upgraded both rear drive shafts for more flex but stock might be enough for you
  7. #166
    Join Date
    Sep 2011
    Posts
    8,422
    2,374
    Default
    Quote Originally Posted by Watsonpreston View Post
    Your saying the driveline concerns are not valid ? Well I see your truck does well off road, now take it on the freeway and lets see how it handles. Especially lets see a emergency swerve to avoid an accident.
    Before you do go on the freeway it would be wise to add a full rollbar to your truck.
  8. #167
    Private
    Join Date
    Mar 2017
    Posts
    Default
    Thats what I am talking about!!! That lifted 3 axle M35 looks awsome! That lift and tire combo are what I wish mine had. Thank you for sending me a message and link to video showing what it looks like and how it does/articulates off road. Did you do power steering too? How and what gauge steel did you use to lower the rear tandems? Do you have a build series on what it took to pull that off? One of those fire-brush truck exocages you see on M35's that fire departments retrofit would look awsome on that beast! How does it drive out on the road. Do you have air lockers or mechanical lockers? Would it drive on the road similar to stock with no lockers just stock Rockwells with open differentials?
    That is great, and I am sure other M35 owners out there would also agree!
    Thanks again for showing it can be done and what it looks like.
    Shane
  9. #168
    Join Date
    Mar 2014
    Dallas
    Posts
    45
    15
    Default
    Shane
    Yes There is a build thread on my truck it hasnít been updated in a long time
    Power steering I Feel was my most important mod as far as Saftey and off-roading went with a Waterloo Saginaw 710 kit itís a nice setup and good but in extreme off road bouncing it I went through a couple gear boxís. I had a company west Texas off road drill and tap my gear box for hydraulic assist made a big difference very reliable and very strong steering.
    To lift the rear suspension I used a 30 inch section of frame that I had from shortening my truck.
    It has spools and both rears and the front has Detroit style locker in the front.
    I donít drive it on the street for the most part but it handles it ok
    Itís chopped up right now getting it back together with modded 5 ton suspension will be running 53/55 inch tires then I will get a video showing everything
    My old setup I have ran for many years
  10. The Following User Says Thank You to Watsonpreston For This Useful Post:
    davidb56 (11-10-2019)
Similar Threads
  1. bobbed deuce question
    By maliboo66 in forum Deuce Modification and Hot-Rodding
    Last Post: 10-03-2011, 00:48
  2. My new Bobbed Deuce and trailer trip
    By MVrookie in forum Deuce Modification and Hot-Rodding
    Last Post: 06-06-2009, 02:03
  3. Latest BOBBED Deuce
    By 100dollarman in forum Deuce Modification and Hot-Rodding
    Last Post: 06-02-2009, 00:51
  4. detroit lockers in bobbed deuce w/5 ton rear springs
    By miltruckman in forum Deuce Modification and Hot-Rodding
    Last Post: 04-22-2009, 23:03
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
