nyoffroad
- 601
- 93
- Rochester NY
I believe the sound differance that I've encountered was from the IP timeing, if the pump timing is advance a bit you get more power but go to far and it sounds like the engine is coming apart add in the cold advance and it gets REAL loud! Try unplugging the cold advance and see if that quiets it down some if so then you know where to go.
