Page 9 of 9 FirstFirst ... 5 6 7 8 9
Results 81 to 90 of 90
Thread: M35A3 tire changing to 395/85/20 part 1
  1. #81
    General Special T's Avatar
    Join Date
    Aug 2013
    Wetside/ WA
    Posts
    477
    Thanks
    37
    Default
    XL.are.a directional tire and shoild work well in softer material
    ..going forward. Not so much in reverse.
    Its Just How I Roll!
  2. #82
    Private
    Join Date
    Jan 2013
    San Diego ca
    Posts
    Thanks
    Default
    Has anyone put 395s on the front while running regular a3 tires in the rear ? I prefer not to spend all the money at once
  3. #83
    4 Star General M35A2-AZ's Avatar
    Join Date
    Nov 2010
    Tonopah, AZ
    MVPA
    34235
    Posts
    2,925
    Thanks
    804
    Default
    Quote Originally Posted by San Diego baja View Post
    I would keep all the same size tires on the truck.
    Trucks: 43 Willy's MB, 52 M37, 71 M35A2 w/w, 84 m936, 85 M923A1, 85 M929, 84 M925
    Trailers: 66 M332, 92 M105A2, 08 M200A1
    Gen: 03 MEP-803A, 01 MEP-805B
    S-280 Shelter
  4. The Following User Says Thank You to M35A2-AZ For This Useful Post:
    98G (07-16-2018)
  5. #84
    4 Star General tobyS's Avatar
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,900
    Thanks
    2,285
    Default
    Remove the front drive-shaft. They are just enough different that it could cause some serious damage if the front is engaged. I'm going to 4x4, partially because of this cost (and I like the looks/performance).
  6. The Following User Says Thank You to tobyS For This Useful Post:
    gdf902foster (07-17-2018)
  7. #85
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,496
    Thanks
    2,424
    Default
    I would take the spline caps off if you did that. No binding of the drive line for sure.
  8. #86
    Private
    Join Date
    Dec 2017
    Houston, Tx
    Posts
    Thanks
    Default
    I’m adding Goodyear 395s to my A3, on A3 rims. I love the look of the stone shields. I am not running ctis and have no ctis hardware on these rims. Will adding the stone shields throw my wheels out of balance or not impact them?
  9. #87
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,496
    Thanks
    2,424
    Default
    I doubt there would be enough weight to throw off the balance if just using the rock guard.
  10. #88
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,900
    Thanks
    2,285
    Default
    You could put a couple extra nuts on the bolts (that bolt the rims together) to add small amount of weight on the opposite side. A static balance would tell you where you are to begin with.
    One way to static balance is on the truck. I decide which axle set I will repack and put new seals on then remove axles, seals and completely clean the bearings and housing. Reassemble without the seals on one wheel and make the bearing to where you can just feel resistance on turning and then back off about 1/4 turn. With no grease or seal, it will turn easily. Mount the tire and wheel being balanced to that hub....the heavy spot will fall to the bottom. Then add weight to the top until you can turn that heavy spot to 90* and it no longer drops. Move that wheel/tire to one of the other axles and go to the next wheel.
    Install new seals and repack grease then you are ready to go. I think front works best but any will work, the axle is just a bit harder to get back in on the rear.
  11. #89
    Join Date
    Nov 2010
    Tonopah, AZ
    MVPA
    34235
    Posts
    2,925
    Thanks
    804
    Default
    I have some of the M35A3 CTIS weights for the wheels if your interested.
    S-280 Shelter
  12. #90
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,900
    Thanks
    2,285
    Default
    Quote Originally Posted by M35A2-AZ View Post
    Since the CTIS is gone, there is too much weight in the standard weight block.
Similar Threads
  1. Tire changing
    By WillWagner in forum The Deuce
    Last Post: 10-26-2009, 23:06
  2. What is this? M35A3 underhood part
    By Rattlewagon in forum The Deuce
    Last Post: 08-24-2009, 22:05
  3. Deuce part numbers
    By jollyroger in forum The Deuce
    Last Post: 08-13-2009, 13:46
  4. Replies: 24
    Last Post: 03-20-2008, 14:46
  5. Mighty Mite Spare Tire Rack: part needed
    By Mike_Pop in forum Mighty-Mite
    Last Post: 12-04-2007, 17:58
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
