Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 61 to 70 of 70
Thread: Unimog FLU419 Tractor thing?
  1. #61
    General dilligaf13's Avatar
    Join Date
    Aug 2011
    south, florida
    Posts
    535
    Thanks
    30
    Default
    Interesting video
  2. The Following 2 Users Say Thank You to dilligaf13 For This Useful Post:
    Mxbean (02-03-2016), NIck4014 (08-24-2016)
  3. #62
    Sergeant
    Join Date
    Jun 2007
    Billings, MT
    Posts
    81
    Thanks
    Default
    I've heard so many things...but lets get one thing straight....They are unique. I've owned many military trucks the consensus of most is they are all hard to work on...ie..M1070LOL! You have to be Quadruple jointed to work on it. This isn't the only time a vehicle/tractor has gotten ripped for being the best available item at the time. If you understand the process of military purchasing/acquiring you can understand why they chose a Unimog chassis gave it to Case and overlaid the Unimog with an additional 1" steel frame supports and attachments. It was the fastest tractor...compact and could be airlifted ect. Apparently Case and Unimog made lots of Money. Now there are better military units able to do more/quicker than the flu-419. But one thing they cannot do is be stripped down to a Unimog again and live a live as a pick-up. Yeah your thinking slow....I beg to differ. You get rid of all the extra case stuff and you have a highly capable crawler with additional benefits. Put some super fast axles in that thing...tune the engine up...drop some 44" tires on it...it will cruise down the road at 55-60mph. If you understand the Unimog its earlier counterpart you understand it's small cab ect. If you want a larger mog...then go for a Unimog 1300L ect. Or turn that SEE into a 4-door soccer mom SUV with a rear door.
    One nice thing that this High Mobility tractor has disc brakes, a very stout engine OM352, a highly flexible frame provided you get rid of all the extra laden equipment, accessorize till you run out of money. For some...it's money well spent.
  4. The Following User Says Thank You to monstermog For This Useful Post:
    sdflatfender (11-28-2017)
  5. #63
    Colonel
    Join Date
    Sep 2016
    Yampa, CO
    Posts
    312
    Thanks
    71
    Default
    I signed up for this forum, hoping to find someone with operational experience on the FLU-419 HMMH (I also have a SEE), specifically as regards the front-suspension lockout mechanism (HMMH only). Mine leaks, and either needs a total overhaul... or outright removal!
    I own 40 acres of hilly, holey, rocky sagebrush I intend to develop. If I'm transporting a load across my property w/ the forklift, is it better to lock out the suspension, or is this a useless feature that's better off removed for less maintenance hassle?
    No speculation, please! I'd like to hear from ex-military folks who have actual, hands-on experience with these units, if possible?
  6. #64
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,674
    Thanks
    106
    Default
    Quote Originally Posted by dilligaf13 View Post
    Interesting video
    My issue with this video while the guy is hooking it all up is... WHERE IS SOLDIER B?
    I am pretty sure you can't towbar these things eh? even with the bucket removed.
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  7. #65
    2 Star General Migginsbros's Avatar
    Join Date
    Nov 2013
    Berlin-Germany
    Posts
    672
    Thanks
    863
    Default
    Quote Originally Posted by simp5782 View Post
    These wheeled tractors are build to tow not to be towed.
    B.t.w. to all who named it SEE not "thing",
    there´s a tuff field off participants at MV of the month.
    NEED YOUR SUPPORT. https://www.steelsoldiers.com/showth...mber-VOTE-HERE!
    unimogfreunde niederbayern 026.jpg IMG_5910.jpgvoteformigginsbros.JPGvote for Migginsbros.jpg
  8. #66
    4 Star General The FLU farm's Avatar
    Join Date
    Dec 2015
    The actual midwest, NM.
    Posts
    2,480
    Thanks
    1,084
    Default
    Quote Originally Posted by Migginsbros View Post
    Well, they must've thought of them being towed at some point, or a SEE wouldn't have gladhands on the front, too.
  9. #67
    Private
    Join Date
    Apr 2018
    Saskatchewan
    Posts
    Thanks
    Default
    Hi
    I am new here and have had a SEE for a year now and want to drop hydraulic oil and flush system. Anyone know where I can get the filters located on the two back tanks?
    thanks
  10. #68
    Join Date
    Dec 2015
    Posts
    2,480
    Thanks
    1,084
    Default
    They're not really filters, but more like strainers. If for whatever reason you want to replace them rather than clean what you have, they are indeed available.
    Not that I remember from where, but I'll never forget how pricey they were.
    What's the reason you need to flush the system? It sounds like you've already replaced the 10W motor oil with hydraulic fluid, so did you have a catastrophic pump failure?
  11. #69
    Private
    Join Date
    Apr 2018
    Saskatchewan
    Posts
    Thanks
    Default
    Thanks for response, reason for flushing is that on very cold temps we could not operate loader and ended up finding moisture in the tank or should I say water. Decided to clean the backhoe tank and found water there as well
    i will however look into just cleaning them out así found one unit on eBay and was quite pricey as you said
  12. #70
    Corporal professorpg's Avatar
    Join Date
    Apr 2010
    Ft. Lauderdale, FL
    Posts
    30
    Thanks
    Default
    I have been replacing bad hydraulic lines one at a time over
    the last 5 years. It is time to replace them all. Anyone got a source for a
    complete set of lines for a SEE?
    Luv my Mog
    __________________________________________________ _________
    pg
    Living under a kleptocracy.
    No trees were killed in the making of this email...
    however, a large number of electrons were
    horribly inconvenienced.
Similar Threads
  1. Why I won't drive Civillian...... Unimog Wins!
    By saddamsnightmare in forum Unimogs
    Last Post: 11-08-2011, 19:50
  2. Springfield, IL Road Trip--- UNIMOG!!!
    By saddamsnightmare in forum Military Vehicle Road-trips
    Last Post: 12-04-2010, 20:39
  3. Worlds longest unimog recovery
    By surewriting in forum Military Vehicle Road-trips
    Last Post: 12-26-2009, 07:24
  4. Unimog Mileage.....S404.114 Swiss
    Last Post: 03-18-2009, 07:47
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
