drilling brake drums
benand117
cuyahoga falls, oh
Look guys just because i play in the truck a bit doesn't mean i don't take care of it. It gets taken apart and cleaned all the time. this time it just happens to be because it blew a wheel cylinder, and from that it looks like a seal. So all the wheel cylinders and seals will be replaced, and the shoes that have been soaked with brake fluid. drums and other shoes are in good shape.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Somewhere(I think it was Tom) I heard they do drill drums to help with heat dissipation. In my opinion, holes drilled in the drum wouldn't let in any MORE mud than what would get in there anyway. I have had some pretty nasty mud in my brakes after I went for a romp in the goo. Also, I don't think the holes would help bring the brakes back faster. Once the pad gets wet it will still need a certain amount of friction to heat it up and dry out the material.
A
A/C Cages
Guest
Check your local DOT if its legal to drive it on the streets with modified holes drilled in them. In Florida its a hit and miss if you drill them. I do know that you can't drill them on a WV drum and still be legal because my sandrail had them drilled and it was the only thing holding me back from getting it street legal. I changed them over to original drums in the rear and they gave me a plate. Then I put the drilled ones back on it. lol
Tanner
11
Raleigh, NC
Drilling the drums can set you up for crack & stress points to form, leading to drum failure.
I wouldn't recommend it.
'Tanner'
Unforgiven
17
Las Vegas, NV
Yes, brake drums can be drilled. It is NOT to relieve heat. It is to relieve trapped gasses created by the heat. As the brake shoe vaporizes it makes a layer of hot gasses that gets stuck between the metal drum and the shoe. That make the drum brakes fade on long downhill applications. Drilling the drums will allow the hot gasses to escape.
In addition, drilled drums will allow water to escape. So having no brakes as a result of fording some water can be decreased if not eliminated. The shoes will dry much quicker. Knowing this, you have to apply a light pressure to the pedal while fording. This keeps the sand & muck out.
Properly sized, spaced, & chamfered holes will not affect the strength of the drum, nor induce cracking. Defer the drilling to a brake expert.
http://http://www.chtopping.com/CustomRod4/
rickf
1,291
Pemberton, N.J.
Just remember that you are compressing a rotor and spreading a drum. Put a hole in the wrong place and when you hit the brakes hard the drum will come apart.
Rick
bearboley
Circleville Ohio
Well said.
Tanner
11
Raleigh, NC
Nicely worded, but still it goes against what drum brake engineers say...
An incorrect explanation sometimes given for brake fade is heated brake shoes evaporate to generate gas that separate them from the drum. Such effects are easy to imagine, but physically impossible, due to the large volume of gas that would be required for such an effect. A 'gas bearing' - as envisioned - would need gas replenishment as fast as the drum moves, since it has no gas on its surface as it approaches the pad or shoe.
'Tanner'
wdbtchr
St. Louis, MO
My 2cents for what it's worth, if you think about it the whole inside of the brake drum is open next to the backing plate. Water can get in or out all it wants. I've always understood the brake fade from imersion if from the wet friction pad and the brake drum. I ain't no rocket scientist or brake expert.:roll:
Floridianson
2,437
Interlachen Fl.
I like that thought. Plain and simple.[thumbzup]
