Page 88 of 89 FirstFirst ... 38 78 84 85 86 87 88 89 LastLast
Results 871 to 880 of 881
Thread: Behr Paint Jobs- Show me your MV's
  1. #871
    4 Star General Another Ahab's Avatar
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    15,536
    22,693
    Default
    Paint your house in camo and you might not find your way home.
    M35A2 w/Winch SOLD
  2. The Following User Says Thank You to Another Ahab For This Useful Post:
    USAFSS-ColdWarrior (08-12-2019)
  3. #872
    4 Star General
    Join Date
    May 2013
    Posts
    4,138
    2,612
    Default
    Quote Originally Posted by L1A1 View Post
    Now that's an MV guy right there! I guess I'm going to have to paint my house in MERDC then.....
    Matt
    Door and frame had a plastic vulcanized to it and I thought the whole unit needed replaced. After seeing the new cost, I did repair. Now adding a full view storm door and side window. Edit....and steel hand rails.
    Attached Images Attached Images
    M35A3 4x4 "Money Pit"
    M929A2
    (14) 5 tons bought and sold
  4. The Following 3 Users Say Thank You to tobyS For This Useful Post:
    Another Ahab (08-12-2019), L1A1 (08-12-2019), USAFSS-ColdWarrior (08-12-2019)
  5. #873
    conceptualizer at large zebedee's Avatar
    Join Date
    Apr 2010
    Central NY
    Posts
    1,318
    382
    Default NATO green ans Arctic white
    Got the Land Rover Lightweight painted recently. Had a sample of the green sent over from the UK, white was just untinted base. Both were acquired from the local hardware store as water based exterior deck paint. Thinned for spraying and 'thrown on' with minimal masking for glass and rubber for the "motor pool" effect. There could be stencilling done for tyre pressure, voltage of rear trailer socket, axle oils, unit call sign and if appropriate for shipping, a weights panel on each door.
    For the rivet counters: wheels should be 16" with Goodyear Extra Grip tyres - studs optional (which I have a set of), roll cage was a 'keep the wife happy when off roading with baby' mod (hidden by soft top). Spare should be on the bonnet (hood) and bumperette mounted aerial is a personal addition.
    "Doing all the things that you can do." Angus: 42.39.56
  6. The Following 5 Users Say Thank You to zebedee For This Useful Post:
    Another Ahab (08-17-2019), Buffalobwana (08-19-2019), L1A1 (08-17-2019), tobyS (08-17-2019), USAFSS-ColdWarrior (08-17-2019)
  7. #874
    Private
    Join Date
    Sep 2017
    Kzoo Michigan
    Posts
    9
    33
    Default M6611a1
    M6611A1 Winter Verdant
    This is our vacation cabin. It’s a 1995 2 bedroom, single wide, 14’ X 50’, with propane heat, & well water. It was/is pretty rough inside and out. We bought the place on 40 acres near Cadillac, Mi. in the Manistee National Forest. Last Summer, we painted the conex on the property ‘Sand’ with two cans of 9 yo Behr Ultra that was left. After mixing with a drill paint mixer, it went down with a roller and brush very well. It really looks nice. It went on thick and dried with a nice ‘grain’. Searching for Behr paint on the innerwebz brought me here. Then I read this whole thread and it inspired me to paint the mobile home on our vacation property.
    I have always been a militaria buff and appreciate the utility designed into pieces of military equipment & gear.
    We sprayed this with Behr Marquis with several Harbor Freight $20 paint sprayers. I thinned the paint a little so it would spray better. About 6 oz of water to the gallon. We went through three sprayers in one weekend. I had one new in the box HF paint sprayer. It lasted about three hours of painting. It made noise but would not paint. Tried cleaning and lubing. Went to HF and bought two more with an extended warranty. We got almost 90% done when the two new ones failed. Took them back for replacement and then finished the job.
    There is still a sizable amount of trim to do and a couple of places that need to be repainted. Overall, I am very happy with the way it turned out. We go there about every other weekend so, over the next couple of months, I’ll finish it. Besides the trim work, we need to paint the starboard 8’x8’ deck, and the port hatch gangway. There is some camo work to do on the window A/C’s. We may spray the door and window glass with the flat black to reduce the sheen.
    To save a few bucks, we painted the 5% Sand and Black accents with Rustoleum camo spray paint. The color is right, but bled some. It will need to be touched up, as well.
    Posting pix in a minute.
  8. The Following 4 Users Say Thank You to McMacy For This Useful Post:
    Another Ahab (08-18-2019), Slate (08-18-2019), tobyS (08-18-2019), USAFSS-ColdWarrior (08-18-2019)
  9. #875
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    15,536
    22,693
    Default
    Quote Originally Posted by McMacy View Post
    The place looks great.
    Is the fencing to keep something OUT, or to keep something IN?
    M35A2 w/Winch SOLD
  10. The Following 2 Users Say Thank You to Another Ahab For This Useful Post:
    McMacy (08-19-2019), USAFSS-ColdWarrior (08-18-2019)
  11. #876
    Private
    Join Date
    Sep 2017
    Kzoo Michigan
    Posts
    9
    33
    Default
    Mostly to keep in our grand-dogs. If one would split at night, my daughter would worry. We are kind of remote, so it is DARK on cloudy and new moon nights. To keep a low profile when we are there, we don't use much outside light.
  12. The Following 3 Users Say Thank You to McMacy For This Useful Post:
    Another Ahab (08-18-2019), tobyS (08-18-2019), USAFSS-ColdWarrior (08-18-2019)
  13. #877
    4 Star General
    Join Date
    May 2013
    Posts
    4,138
    2,612
    Default
    at night in MI that would blend in fine.
    M929A2
  14. The Following 2 Users Say Thank You to tobyS For This Useful Post:
  15. #878
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    15,536
    22,693
    Default
    I learned to embrace darkness, it was a lesson learned from, believe it or not, some Navy SEALS:
    - Our battalion (SEABEES) was billeted with a SEAL TEAM once on a deployment to Puerto Rico (Rosey Roads).
    - Why we were together is beyond me...
    - Anyway those SEALS talked about LOVING the darkness, and preferring it for almost all their operations
    - They noted that depending on lights at night can actually blind you to what's around you
    - Letting your eyes get used to the darkness you can actually see more (overall) than you can with a light
    - Also, it's human nature not to like being out at night, and SEALS apparently make the most of that
    That's some of what we learned from those SEALS. That's it. The End
    M35A2 w/Winch SOLD
  16. The Following 3 Users Say Thank You to Another Ahab For This Useful Post:
    CARMAN (08-18-2019), McMacy (08-19-2019), USAFSS-ColdWarrior (08-18-2019)
  17. #879
    4 Star General fuzzytoaster's Avatar
    Join Date
    Aug 2009
    Dallas, TX
    Posts
    3,418
    916
    Default
    Sometimes 383 is nice just the way it is. Ya know?
    M1078A1 -5x
    M1078A1R
    M1089A1
    M1084
    M1078 -3x
    M1083 w/w 2x
    M1083A1
    M1082 -2x
    M1088A1 2x
    M1088 2x
    M1123
    M923A2 LWS 16's A/C
    M929A2
    M925A2 "Buffalo" Trainer
    M876 TMT
    M105A2 -2x
    M989A1
    Hyster H40XM
  18. The Following 4 Users Say Thank You to fuzzytoaster For This Useful Post:
    Another Ahab (08-18-2019), McMacy (08-19-2019), tobyS (08-18-2019), USAFSS-ColdWarrior (08-18-2019)
  19. #880
    3 Star General TechnoWeenie's Avatar
    Join Date
    Feb 2013
    Melmac / WA
    Posts
    935
    306
    The only good cat is a stir-fried cat
    • '84 M934
    • '86 M1031
  20. The Following 5 Users Say Thank You to TechnoWeenie For This Useful Post:
    bikeman (10-16-2019), cwc (10-11-2019), L1A1 (10-19-2019), McMacy (10-13-2019), USAFSS-ColdWarrior (10-11-2019)
Similar Threads
  1. Combat Garage -New show on History Channel
    By creinemann in forum Upcoming Events
    Last Post: 02-01-2007, 01:41
  2. MV show in Silver Lake MI. sat. sept. 16th
    By 67Beast in forum Upcoming Events
    Last Post: 09-15-2006, 06:34
  3. Replies: 6
    Last Post: 04-18-2006, 09:59
  4. Military Show & Swap meet in Silver Lake Michigan
    Last Post: 03-04-2006, 10:25
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
