Black Widow Replica Gun Truck in Florida
maddawg308
723
Front Royal, VA
does anyone know how many replica gun trucks there are out there? It would be cool if someone could build a gun truck that is one of the ones with a M113 APC body in the back end of a 5-tonner.
1,813
Where in FL is the Black Widow? I'd love to see all these gun trucks assembled in one place.
vtdeucedriver
Vermont
Pensacola fla kenny
GT replicas in the USA
ACE OF SPADES...... TN (5ton)
THE UNTOUCHABLES...........NJ (5ton)
SATANS LIL ANGEL...............NJ (5ton)
MALFUNCTION....................NJ (3/4 ton)
PSYCHOTIC REACTION..........NC.....(2 1/2 ton)
BLACK WIDOW....................FLA (5ton)
UNCLE MEAT...................?????Think Michigan (5ton) being built
WILD THING.......WI............5ton
Kenny, most if not all will attempt to be at FT Eustes in 2007
vtdeucedriver
Vermont
Hey larry.............Ive been askin around..............a couple of guys here in the area are working on there stuff in the spring. Brandon (AMGeneral) is working on bringing either his M62A1 or M54A1. Then there is another M52A2 in the works...................as you also know, I will be there with mine:)
halftrack
9
New Orleans, LA
Can anyone post a close up picture or explain how they attach the metal plates to the doors and windhsheilds. Is it welded or just bolted. Can the door hinges support the extrea weight. I would love to build a guntruck and just want to do it historically correct.
Uglyranger
Waverly Hall, Georgia
The 3' x 4' plates were welded in the box and on the driver and passenger door. The windshield armor was hinged and folded down. Here is a picture of the Uncle Meat gun box being taken off of a destroyed truck, and being prepared for a new truck.
The Ace of Spades, replica gun truck in Rogersville, TN, has a welded rear box and aluminum door armor, using bolts on the hinges, and another on a centered horse-shoe shaped mount below the door handle.
