Page 5 of 5 FirstFirst 1 2 3 4 5
Results 41 to 45 of 45
Thread: Gamma goat only goes Thirty Miles an hour..
  1. #41
    Sergeant Major Joe Gamma's Avatar
    Join Date
    Jul 2011
    Middleboro Mass
    Posts
    125
    Thanks
    32
    Default
    I can not say definatly I know. The Governor actually has adjustment screws..One outside made the engine rev higher but no additinal speed..The second you had to take off a small cover and two bolts, just increased the idle rpm and nothing else...There is a third screw that I havn't the time to screw with, yet that may be the key which I believe is in the Govenor...
    The real reason I stopped is I am replacing the steering box so I would not drive it faster now anyway...
    I will find the diagram and send it to you if you pm me your e-mail...but I am away till monday.
    Joe
  2. #42
    Sergeant Major goat whisperer's Avatar
    Join Date
    Nov 2009
    Bremen, Germany
    Posts
    165
    Thanks
    23
    Thumbs up governor adjustment...
    After I replaced the injectors I wanted to adjust the governor too to get the maximum out of the engine. By that time John Smith, a member of the yahhoo gama goat group, provided the instruction for adjustment to me, cause I had no idea how to do...
    GOVERNOR ADJUSTMENT (by John Smith)
    Greetings from Northern Germany,
    Ulf
    Gama Goat Europe... my other MVs and friends...
  3. The Following User Says Thank You to goat whisperer For This Useful Post:
    m561gamagoat (11-06-2012)
  4. #43
    Sergeant Major m561gamagoat's Avatar
    Join Date
    Jul 2012
    Akron/Ohio
    Posts
    104
    Thanks
    14
    Default
    Wow sounds complicated. I will have to walk through it before doing it. Thanks though.
    "We're surrounded. That simplifies the problem!"
    1970 M561 Gamagoat
    1972 M35A2
  5. #44
    Join Date
    Nov 2009
    Bremen, Germany
    Posts
    165
    Thanks
    23
    Thumbs up yes....
    Quote Originally Posted by m561gamagoat View Post
    it is complicated...but most important to get the maximum out of the DD 3-53.
    I needed several days to adjust the governor. For testing you allways have to take the goat on the road and after the ride perhaps doing the work again...and again... After I finished my goat goes a little more than 60 mph
    Ulf
  6. #45
    Join Date
    Jul 2011
    Middleboro Mass
    Posts
    125
    Thanks
    32
    Default
    When I first got my Goat the old guys kept scaring me about 3-53's running away. I will probably leave that to the pros but would love a RPM indicator on the beast.
    Joe C
    Thanks again Ulf on the Governer Stuff...
Similar Threads
  1. Gama Goat Safety
    By JDToumanian in forum Gama Goat
    Last Post: 04-08-2017, 10:58
  2. gamma goat tailgate
    By fusn in forum Gama Goat
    Last Post: 09-30-2011, 22:00
  3. Mule Hour Meter Gear Drive
    By JDToumanian in forum M274 Mechanical Mule
    Last Post: 12-09-2010, 12:39
  4. hour meter questions
    By JungleBiker in forum 5-ton and up
    Last Post: 07-20-2010, 19:35
  5. Georgia really
    By panzerwillie in forum Upcoming Events
    Last Post: 10-06-2009, 21:58
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
