- 14,583
- 4,596
- 113
- Buchanan, GA
So I pulled the trigger on a goat from a CAMO member. It's still at papabear's place, but it will make the trip back home when we can work out the times. I know there's no brakes on it right now. The MC cap is off and there's no fluid left in there. They drove the goat around last time it was running but one or possibly both of the rear tires were locked up. I know the driveshaft has been disconnected. Is it possible the brakes are simply seized up like the 900 series trucks do? I was able to turn the drive shaft slightly, so I know the pinion is still loose.
Can the goats be driven with the "trailer" removed? Or maybe with the drum removed? I know the U joints on the drivers rear axle need replacing as well. Probably going to go through all of them.
Does anyone have any TM's for them? I'd love to upload them to the site for everyone.
