VIC-1 Install
bigmike
354
Dixon CA.
finished my VIC-1 install
Thanks to Tinwoodsman for the pics and ideas for mounting.
I made some brackets and existing holes and hardware on the truck so I didn't drill any holes.
I made the brackets for the individual boxes slotted to accomidate the 1/8" difference in needed length.
The only problem I have is in one of the headsets. You have to switch and hold on "RAD" in order to talk whereas the other headset you can hear and speak while swtiched to "ICS".
Tinwoodsman
75
Comfort, Texas
Looks good. Your attention to detail puts my install to shame. As for the problem headset, did you swap them and see if the problem follows?
bigmike
354
Dixon CA.
The problem follows the headset. I'm hoping Steve Haney will contact me with a simple fix.
Tinwoodsman
75
Comfort, Texas
Steve us good. I am sure he will. Periodically I use a pencil eraser and clean the contacts on the headset plugs and the control boxes. Good luck.
IroncladGA
Atlanta
to follow up on the questions about cleaning the contacts, I have two AM-1780s that I can't get to work fully. The relays click when the PTT buttons are activated, but no sidenote is heard (in the first AM-1780), and a sidenote is heard (but no audio) on the second one. I know it's not the cables, headsets, or c-2298s because I have used them all on another 1780 and everything works just fine. Anyway to clean the tiny female connectors on the 1780. I read the TM, which advises sending to maintenance and requisitioning a replacement, but that option doesn't work so well for me.
Thanks for any help.
