Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 40 of 49
Thread: How to repack wheel bearings?
  1. #31
    4 Star General Floridianson's Avatar
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,742
    Thanks
    2,375
    Default
    Rusty the microwave is not as good as the oven set at 120*. This is the lowest I have seen my grease packed bearings run on the hub.
    Now if one got the bearings to tight or is overloading the truck then well you get the Idea.
    Razor did you pack your hub. I buy the grease in 5 Gal. bucket's
    Real trucks don't have spark plugs! Me strong as bull smart as tractor. James
  2. #32
    4 Star General RAYZER's Avatar
    Join Date
    Feb 2010
    sanford/florida
    Posts
    3,358
    Thanks
    2,101
    Default
    I do pack some grease in the hub but not full.
    Are you putting your wheel bearings in tne microwave James?
    Ray
    1986 m105
    1968 m146 RV conversion
    1968 m35a2 road tractor
    1963 m246a1 (mack)
    M373 Van trailer
  3. The Following User Says Thank You to RAYZER For This Useful Post:
    m1010plowboy (03-20-2016)
  4. #33
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,742
    Thanks
    2,375
    Default
    No I like my bearing's uncooked or raw. The microwave make them tuff to chew. Now the wad of grease I put in the oven to watch it lay down for a test.
  5. The Following 2 Users Say Thank You to Floridianson For This Useful Post:
    frank8003 (01-10-2019), silverstate55 (01-10-2019)
  6. #34
    4 Star General HanksDeuce's Avatar
    Join Date
    Jun 2011
    Prairieville, LA
    Posts
    1,027
    Thanks
    693
    Default
    I bought a bearing packer from one of the local parts stores. Very easy to use and doesn't make a mess. Note the deuce wheel bearings barely fit, but they do!
    Attached Images Attached Images
    1970 M35A2 W/W - Build Thread - My Deuce Website - YouTube Channel - 27.34@48.11mph
    >Big Mods: Cummins 6BT, Allison AT545, Hydroboost brakes, Bobbed, 8" Lift, 53" Michelins, Power Steering, Disc Brakes, 28" Drop Double Hitch, 5 ton spare tire rack/toolboxes, Vintage Air A/C, Rear Locker
    >Lil Mods: Warn 18k winch, Brush Guard, Air Ride Seats, Lockout Hubs, Train Horn, LEDs, 50A equalizer, 12/24v fuse boxes, Autometer/ISSPro Gauges, Backup Alarm, Air Shutoff Valve, Lizard Skin Coatings
  7. The Following 2 Users Say Thank You to HanksDeuce For This Useful Post:
    Guyfang (01-10-2019), silverstate55 (01-10-2019)
  8. #35
    4 Star General Jeepsinker's Avatar
    Join Date
    Aug 2013
    Dry Creek, Louisiana
    Posts
    5,036
    Thanks
    1,057
    Default
    I pack my hubs full, and they run at ambient temp. Most of the time they even feel cool/ lukewarm to the touch. My infrared temp gun reads them all around 80 degrees after hours on the road.
    I sink Jeeps... That is all
    1969 Kaiser Jeep M35a2 w/winch (Daily driver, no joke)
    Now a hot rod deuce: 6BT swap in progress, Waterloo overdrive, 2 micron fuel filtration installed, riding on 11.00r20s
    1971 M151A2 w/ ROPS
    3: 87' M35a2c Air Force trucks (for sale)
    1991 BMY M936a2 wrecker
    2: M1061 flat trailers
    1: Fresh rebuilt and load tested good Mep003a genset(for sale)
    I do Fort Polk and other recoveries in my state. I can be reached at 337-401-2470
  9. #36
    4 Star General
    Join Date
    Mar 2004
    Baton Rouge, LA
    Posts
    1,053
    Thanks
    300
    Default
    I have a question or two on wheel bearing servicing.
    I last did all the bearings and brakes on a Deuce about 8 years ago so I am rusty.
    I have all of the TMs in PDF and I see the information in this thread on the area of instruction for the bearings.
    I "thought" that I remembered an area where a cork is installed in the keyway of the spindle and sealed in place but it is not mentioned in the TM or at least I have not come across it yet.
    Does anyone recall this elusive tidbit of info or is it not for this truck?
    I ask because when my truck have a wheel cylinder stick last week, I
    pulled the rear hub and discovered that all the grease was washed out by gear oil due to leaking seals, etc.
    I want to do all of my bearings while I am changing wheel cylinders and flex hoses and want my new grease to stay put where it is supposed to be.
    If I do not get it transported to my new home area I will be driving it 700 miles instead.
    Engine oil & filters done, fuel filters done, and gear oils to be done. Everything is getting freshly lubed.
    Note; If you can recommend a new conventional gear oil for yellow metal, that would be great too as I have not purchased any for 8 years now. I also want to do the bearings on the rear boggies as they have probably never been done unless the truck has have axles replaced sometime since 1970.
    Thanks for reading.
    jimm1009
  10. #37
    Banned
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,026
    Thanks
    2,257
    Default
    Quote Originally Posted by jimm1009 View Post
    Thanks for reading.
    jimm1009
    The "cork" is used to seal the "keyway" on the spindle, keeping differential fluid from entering the wheel bearings. You can use a good silicone, but the cork or a similar material is best.
  11. #38
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    3,331
    Thanks
    2,291
    Default
    I have a question or two on wheel bearing servicing. ~ cork is installed in the keyway of the spindle ~ freshly lubed ~ Note; If you can recommend a new conventional gear oil for yellow metal, jimm1009
    After much research, and I mean a lot of research, I serviced all the axles with new copper squish washers and this lube. I got the VV829 from Amazon as it was shipped to here as is still available.
    gear oil Deuce differentials oil A 07262013.jpg gear oil Deuce differentials oil B 07262013.jpg
    I put no grease in the truck except what the TM said to use which is GAA.
    Yes, I bought two cases of GAA, many on here scoff at that but it is what the TM's say to use, never had a problem with it and I like the smell of it..
    About the cork in the keyway, I made my own and sealed that in with RTV, none of them ever leaked again. I had a hard time finding a bottle of wine with the proper cork to use, lots of plastic nowadays, but I persevered. The cork in the keyway thing is mandatory and been covered many times in SS. Here is a bit of my findings on cork for the axle keyway from many contributors.
    Note that the axle keyway must be really really clean (think trichloroethane and brake clean stuff) to pack the cork in there and seal it with RTV and let it dry.
    The information as it exists that you seek is in here about the cork.
    If it just looks like a black box to you click on it as the TB is there.
    TB-9-2300-426-20 brakes cork seal.pdf
    Or you could start your own search by using the search box and get this
    https://cse.google.com/cse?cx=partne...6do%3Deditpost
    I was here, had a good time.
  12. The Following 5 Users Say Thank You to frank8003 For This Useful Post:
    cattlerepairman (01-10-2019), Migginsbros (01-10-2019), Roller (01-10-2019), rustystud (01-11-2019), silverstate55 (01-10-2019)
  13. #39
    Colonel Ajax MD's Avatar
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    331
    Thanks
    84
    Default
    Holy cow, where did you find that old comic book style tech note, Frank!?
    Motorpool:
    (Isn't owning one of this insanity enough??)
    1971 M813 "Ox" (named for Dewey Oxburger)
  14. #40
    Corporal
    Join Date
    Sep 2018
    PA
    Posts
    30
    Thanks
    20
    Default
    As a millwright I find the cork insert fantastic! Simple but elegant and the porous nature of the cork would be great for the Rtv to stick to. As mentioned above, those surfaces have to be CLEAN for the rtv to stick. No oil or crease residue at all on any of the metal parts or the surface of the cork you want it to stick.. Rubbing alcohol would probably do the job just find just make sure it's super clean and give the rtv a full 24 hrs before returning to service to set properly. If you get grease on the cork, you'll probably have to use a new one. Doubt you would be able to get that surface clean once contaminated.
  15. The Following 2 Users Say Thank You to 13ronin For This Useful Post:
    frank8003 (01-10-2019), jimm1009 (01-10-2019)
Similar Threads
  1. M211 Wheel bearings
    By firefox in forum The Early Deuce
    Last Post: 07-14-2014, 21:34
  2. Confused about wheel bearings and lube on deuce
    By maddawg308 in forum The Deuce
    Last Post: 09-17-2008, 13:48
  3. Deuce wheel bearings...or lack of!
    By randyscycle in forum The Deuce
    Last Post: 09-17-2008, 11:28
  4. Front wheel bearings
    By sermis in forum The Deuce
    Last Post: 01-07-2007, 12:05
  5. wheel bearings and seals
    By Big Mike's Motor Pool in forum The Deuce
    Last Post: 04-26-2006, 07:36
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
