Page 835 of 841 FirstFirst ... 335 735 785 825 831 832 833 834 835 836 837 838 839 ... LastLast
Results 8,341 to 8,350 of 8407
Thread: What have you done to your 5 ton this week?
  1. #8341
    4 Star General BenRoberts's Avatar
    Join Date
    Mar 2016
    southwest/ohio
    Posts
    1,166
    Thanks
    325
    Default
    Doing some pm on mine belts, oil change and a fuel filter.
    1984 AM General 923 (Shrek) aka Big Girl.
    If you need it and don't have it, you're singing a different tune
    Ohio motorpool member
  2. #8342
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,520
    Thanks
    106
    Default
    Quote Originally Posted by BenRoberts View Post
    I bet you aren't doing a water pump belt cause I would hear you cussing from here I am sure.
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  3. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    BenRoberts (02-09-2019), tobyS (02-09-2019)
  4. #8343
    Join Date
    Mar 2016
    southwest/ohio
    Posts
    1,166
    Thanks
    325
    Default
    Quote Originally Posted by simp5782 View Post
    She's getting all of them. Hoping like he!! She seals up going back on.
  5. #8344
    Colonel US6x4's Avatar
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    202
    Thanks
    Default
    I shoveled a path out to my truck to test the new-to-me wheel chocks in their racks.
    I added some rubber Edge-Lok trim to my AM-1780 since it will be mounted up and behind everyone's head.
  6. The Following User Says Thank You to US6x4 For This Useful Post:
    Buffalobwana (02-10-2019)
  7. #8345
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,520
    Thanks
    106
    Default
    Logged 1800 miles Thursday thru Sunday morning. Drug a 923 home along the way and carried an LMTV to Dallas.
    Got home today about noon and installed a new LED bar on the rear of my truck. Installed the Trucklite lollipop lights up on the bumper cause i needed a little more for those dark windy roads. Also put a bigger intake tube on the air filter. Replaced the rear valve cover gasket as well.
    Also did some lighting work on my trailer.
    Attached Images Attached Images
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  8. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    Amer-team (02-26-2019), Rmtaunton (02-11-2019)
  9. #8346
    Join Date
    Mar 2016
    southwest/ohio
    Posts
    1,166
    Thanks
    325
    Default
    What is that on the right side of the bumper sticking up in the air?
  10. #8347
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,520
    Thanks
    106
    Default
    Crew Duke antenna. It's for IEDs. I live in Memphis. It's getting pretty bad around here
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  11. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    TechnoWeenie (02-10-2019), youngDUMP (02-10-2019)
  12. #8348
    Join Date
    Mar 2016
    southwest/ohio
    Posts
    1,166
    Thanks
    325
    Default
    That ain't no lie
  13. #8349
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    202
    Thanks
    Default
    I installed a new M816 flood light switch and data plate on my M813 for future off-road lights or light bar.
    I went at it from the passenger side trying to pop the knockout out and I got stuck in my cab. I couldn't move forward or backward, had the tranny shifter up my jacket, the t-case shifter in my left pocket, and the winch lever jabbing into my hip. I got freed finally but it took some effort & a few muscle spasm to do it...
  14. The Following User Says Thank You to US6x4 For This Useful Post:
  15. #8350
    Colonel Ajax MD's Avatar
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    326
    Thanks
    84
    Default
    Quote Originally Posted by US6x4 View Post
    Meanwhile, your cell phone is going off in your pocket and you can't reach it...
    Motorpool:
    (Isn't owning one of this insanity enough??)
    1971 M813 "Ox" (named for Dewey Oxburger)
Similar Threads
  1. 5 ton vs 10 ton
    By m.walker in forum 5-ton and up
    Last Post: 04-25-2018, 00:45
  2. 5 ton pricing!?
    By TadB in forum 5-ton and up
    Last Post: 10-18-2015, 07:21
  3. 5 ton drama..
    By Rene M in forum 5-ton and up
    Last Post: 01-01-2010, 21:38
  4. Warner Robbins Ga. A2C's
    By TIGERFANS2 in forum The Deuce
    Last Post: 12-03-2009, 07:04
  5. 5 ton towing a 55 ton tank
    By davesgmc in forum 5-ton and up
    Last Post: 06-14-2009, 22:30
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
