Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 38 of 38
Thread: Gamma Goat wheel hub Maintaince
  1. #31
    2 Star General Gamagoat1's Avatar
    Join Date
    Sep 2006
    Elizabeth, Colorado
    Posts
    728
    142
    Default
    Doghead,
    Just downloaded -20. It worked. Look through the different downloads. I uploaded a -20 and it still works. The second "More Gamagoat Manuals" holds the -20
    Mike
    MVPA #171
    MVCC
    USN 4/64 - 7/72
    1971 XM-816 "Cap'n Hook"
    1972 M-561 GamaGoat
    "The Only Easy Day Was Yesterday"
    God, Bless America!
  2. #32
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    967
    Default
    Quote Originally Posted by Gamagoat1 View Post
    Doghead,
    Mike,
    That's the -20-1 and it does work but is pretty much just PMCS and the LO. The other volumes have more of the maintenance guidelines we've been looking for. I have a complete set ordered and hopefully can upload the others when they arrive.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  3. #33
    Join Date
    Sep 2006
    Elizabeth, Colorado
    Posts
    728
    142
    Default
    The one I uploaded is 500 pages, a little more than PMCS. I just checked it again and it works fine
    Mike
    MVPA #171
    MVCC
    USN 4/64 - 7/72
    1972 M-561 GamaGoat
    God, Bless America!
  4. #34
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    967
    Default
    I'm seeing 1 -20 and 2 -10s (-10-2 and -10-3) on the page you have listed. If there is something else regarding the -20s could you post a link here?
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
  5. #35
    Join Date
    Sep 2006
    Elizabeth, Colorado
    Posts
    728
    142
    Default
    PM me an email and I'll send you the TM9-2320-242-20
    Mike
    MVPA #171
    MVCC
    USN 4/64 - 7/72
    1972 M-561 GamaGoat
    God, Bless America!
  6. #36
    Private
    Join Date
    Mar 2015
    Meriden,CT
    Posts
    Default
    Hey Joe,
    i just bought an 1971 M561 Gama Goat and lost brakes on highway after doing 50 down 91 S in CT for 40 mins and front drivers side tractor drum stated smoking. I took it apart and cannot bleed any fluid from any wheel cylinder...do you have ant ideas? Am I missing something like a valve under the baby somewhere. I will also say the master cylinder had two different color fluids, 1 was brown and 1was red, I've read that is pretty common. My plan was to drain and bleed all the lines and put all new dot 5 in....although I can't get a drip out of any thing...any help would be greatly appreciated.
    Dave
    203-605-6723
  7. #37
    4 Star General Jericho's Avatar
    Join Date
    Mar 2012
    Landaff NH
    Posts
    1,104
    66
    Default
    Assuming there is fluid in the reservoir , a good place to start is the front wheel that was dragging, only reason they drag is if the extended slave cylinder fails to return fluid and the shoes stay extended pull the brake drum, cinch a thin cargo strap around the shoes , tight, loosen the bleed screw on the slave cylinder and have some some one pump your brakes down , hold tighten bleeder, pedal up . loosen the bleeder, pedal down, repeat, ensure you keep fluid (dot 5 ) in master cylinder, repeat until you get fliud ( slave cylinder is likely bad) . rubber flex hoses are likely originaly , they sometimes collapse check each wheel
  8. #38
    Private
    Join Date
    Mar 2015
    Meriden,CT
    Posts
    Default
    Thanks, I'll be under her tomorrow morning...
    Best,
    Dave
Similar Threads
  1. M105A2 Wheel/ Hub Conversion
    By EZDUZITBEAR in forum Trailers
    Last Post: 11-01-2014, 00:15
  2. 'Gamma Goat flasher unit for Directionals"
    By Joe Gamma in forum Gama Goat
    Last Post: 12-27-2011, 03:47
  3. Gamma Goat Handling
    Last Post: 08-23-2011, 01:30
  4. M 105 Wheel Hub Question
    By shrevestang in forum Trailers
    Last Post: 12-15-2007, 00:00
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
