GA 1954 Willys-Jeep M38A1. Lots of work done, good driver/parade truck. $11.9K
Steel Soldiers is supported by:
114
1954 Willys-Jeep M38A1. This is my client’s Jeep and I’ve done 99.9% of the work to it since he acquired it. He is moving in a different direction in the hobby and is putting the Jeep up for sale and since I’ve done all the work for the last 4+ years, I’m helping him sell it. $11.9K obo
Details: Currently registered and tagged in Georgia, current owner has the title from the prior owner in Florida (Georgia will not title anything built prior to 1963). Located in Winder, Ga. Vehicle has recently been serviced with new oil and filter, all fluids checked, all zerks greased, etc. All systems on vehicle function as they should: Engine, drivetrain, 4wd, gauges, lights, parking brake, etc.
Condition: Vehicle is in very good driver or parade duty condition. Sheetmetal is above average, but not perfect. Both front fenders were wrinkled at some point and straightened. They are acceptable in their current condition but a new owner looking for show quality perfection will probably want to replace them. Tub corners, rockers, cowl and rear panel are excellent. Vehicle had a replacement floor pan installed at some point and the job was done competently. Rear panel is straight and has never had a tailgate cut in. Windshield is correct M-series Jeep (it’s an M170 ambulance Jeep model, but it’s identical to M38A1 other than two small brackets on top for stretchers) and has new glass and weatherstripping. Vehicle retains all of its original 24V system (25A generator, external regulator, blackout lights, etc.). Most of the wiring is new and retains the original Douglas connectors. The paint is older and a few spots have been touched up but overall it’s a clean and presentable vehicle. Vehicles runs very well, will maintain 50mph, transmission doesn’t pop out of 2nd gear like so many T90s, transfer works like it should, etc. Carburetor is the correct Carter YS950, etc.
Work that I’ve done:Installed 24-12V converter (15A) to power parade light/siren/power port
Full tune up with new points, condenser, coil, cap, etc.
Full rebuild of carburetor and tuning
Rebuilt parking brake assy.
Resealed transfer case driveshaft flanges and converted transfer case to having low range 2 wheel drive capability (removed shift interlock, not a permanent modification and can easily be put back to stock)
Replaced master cylinder, flushed brake system and bled with new DOT BFS
Flushed radiator
Drained all fluids and refilled with correct GL1 90W.
Rebuilt front steering linkage with new bellcrank, tie rods and tie rod ends (X4)
Replaced timing gears
Replaced bottom end of engine: the oil pan was full of sludge, starved engine of oil and spun #4 bearing. I cleaned out the pan, cleaned out the pickup, removed the engine, removed the crank and #4 piston/rod assy. and bought a replacement crank, had the new crank turned, installed replacement #4 rod, all new main and rod bearings and out everything back together. I used plastigauge on every single bearing to check clearances and all were within spec. Engine has had multiple oil changes since overhaul and never has any metal shavings in the filter.
Installed new radiator core support felt and correct rivets
Painted a replacement rear seat in the correct color and upholstered the seat in NOS upper and lower cushions with correct hardware.
Installed fire extinguisher
Valves adjusted
Built a really cool military police spare tire cover, using an original steel disc (we copied the size and font of the lettering exactly) that requires no tools to remove and didn’t modify the Jeep in any way.
Fuel tank has a rebuilt pickup assembly. New filter, sandblasted and coated the assy. to stop any rust from getting into the fuel system. Also has a new sending unit
Hidden kill switch with key for safety
Replaced oil filter hoses
Electric windshield wiper on drivers side for reliability
Ok, I have a brazillion images of this thing. So be patient.
20191101_112615.jpg20191101_111613(0).jpg20191101_111648.jpg20191101_111658.jpg20191101_111715.jpg20191101_111740.jpg20191101_111800.jpg20191101_112017.jpg20191101_112432.jpg20191101_112658.jpg20191101_111747.jpg20191101_112608.jpg20191101_112218.jpg20191101_112215.jpg20191101_112211.jpg20191101_112208.jpg20191101_112157.jpg20191101_112100.jpg20191101_112041.jpg20191101_111751.jpg
114
20191101_111715.jpg20191101_111732.jpg20191101_111735.jpg20191101_111813.jpg20191101_111817.jpg20191101_111821.jpg20191101_111828.jpg20191101_111835.jpg20191101_111838.jpg20191101_111931.jpg20191101_111946.jpg20191101_112307.jpg20191101_112254.jpg20191101_112249.jpg20191101_112247.jpg20191101_112244.jpg20191101_112012.jpg20191101_112006.jpg20191101_111956.jpg20191101_111952.jpg
114
20191101_112322.jpg20191101_112323.jpg20191101_112354.jpg20191101_112400.jpg20191101_112404.jpg20191101_112619.jpg20191101_112621.jpg20191101_112626.jpg20191101_112629.jpg20191101_112632.jpg20191101_112633.jpg20191101_112645.jpg20191101_112651.jpg
114
Ok, now all the pictures of the work I have done to it.
Re-indexed the oil pump because it was not where it should have been (so the #1 plug wire would be in the right place)
New cam gear
20160425_205104.jpg20160426_183052.jpg20160426_190135.jpg20160426_190154.jpg20160501_210942.jpg20160504_145701.jpg
Carb rebuild w/ correct Midwest Military kit
Full rebuild of fuel tank pickup unit
20180825_193536.jpg20180825_193534.jpg20180825_193524.jpg20180825_202944.jpg20180830_193810.jpg20180830_193148.jpg20180830_193808.jpg20180830_195101.jpg
114
New exhaust, new hardware, etc.
Spare tire cover
Repainted rear seat, installed NOS seat cover w/ new hardware, painted brackets, etc.
20180715_125931.jpg20180725_210607.jpg20180725_210616.jpg20180725_210625.jpg20180727_202738.jpg
New master cylinder and system flushed w/ DOT5 BFS
20170418_174110.jpg20170418_174102.jpg20170418_145621.jpg20170418_145613.jpg20170418_145605.jpg
114
And the biggest part, the engine repairs.
Short story: unbeknownst to us, the oil pan was so full of sludge, the pickup was starved for oil. So it spun the #4 rod bearing.
20160523_193942.jpg20160523_193952.jpg20160523_193956.jpg20160523_194021.jpg20160523_194026 captioned copy.jpg20160527_190324.jpg20160527_190337.jpg20160527_190431 captioned.jpg
Pull the engine:
20160709_133326.jpg20160709_133339.jpg20160709_193035.jpg20160710_212923.jpg20160710_212925.jpg20160710_220607.jpg20160710_223802.jpg20160710_223800.jpg20160710_223755.jpg
114
We replaced the crank and #4 rod. New bearings, turned a replacement crank. Checked everything with Plastigage.
20161116_194320.jpg20161116_194905.jpg20161116_195625.jpg20161117_154102.jpg20161117_154106.jpg20161117_154110.jpg20161117_171950.jpg20161117_171953.jpg20161117_171957.jpg20161206_172127.jpg20161206_174226.jpg20161206_183557.jpg20161223_130631.jpg20170324_195713.jpg20170324_195722.jpg20170324_195729.jpg20170330_121829.jpg20170330_113050.jpg20170329_204033.jpg20170329_201952.jpg
114
20170330_121842.jpg20170330_131805.jpg20170330_131809.jpg20170330_173339.jpg20170330_185758.jpg20170401_140912.jpg20170401_141702.jpg20170401_175044.jpg20170401_190626.jpg20170401_190630.jpg20170413_180713.jpg20170413_181813.jpg20170415_112539.jpg20170415_112547.jpg
114
bump
114
Bump and price drop to $11,900.
114
bump
114
Someone come buy this Jeep. It's lovely
114
bump
114
bump
114
bump
