AL 1972 AM General M109A3
Steel Soldiers is supported by:
fpchief
72
Bay Minette, Al.
Alot has been done in this truck. From front to back....new return lines, FDC bypassed, new HH O rings, injectors tested, compression tested, new fuel lines, all new filters and fluids, flame heater removed, fuel tank removed and had a shop put a new bottom in it and they did an excellent job, new in tank pump, new sending unit, new seat covers, new paint in cab, removed hard top top and repaired rust, new hard top insulation, went through all hubs, replaced all seals on all axles, replaced all wheel cylinders. Both windshields are brand new and both doors are brand new. Brand new J-pipe.
For the box....completely gutted it inside. Replaced most of the roof, Removed floor and rusted metal underneath, installed double layer of marine grade 3/4" plywood and covered that laminate, all new insulation in the walls ran led overhead lighting, has several 12v drops along the sides. Also Installed LED floodlights on both sides and back of the box. Installed regular 12v roof fan like on and RV and also a maxxair roof fan. I did seal off the middle two windows. $6800.00. 251 250 9669
