MA 1992 MEP002A 1800RPM 5-KW 1800RPM Diesel Genset $1,350
Steel Soldiers is supported by:
Light in the Dark
230
MA
Unit has 2200 hours. It runs strong and produces good power (load bank tested). The fuel pumps are very tired sounding, but it runs like a top. The fuel filters will need to be changed (as not been done)... this could be contributing to the slow pump noise. Dumped the oil and upgraded to spin on filter kit in the last month. Fresh 15w-40 in it. I had to replace the primary fuel line into the injection pump (it was leaking like a civ, can see the drip leak on videos below) with a custom fab hydraulic hose from NAPA. Dry as a bone now. Some degreasing has been done below this leak, but the skid is still stained a bit.
The hertz meter and the battery charge gauge were both operational when I first received it. Neither are currently working. It might be a ground concern, it might not. I will be including a brand new battery charging alternator (the fuse is good, and the gauge I believe is also good... both were swapped out with working units and same issue continued) for no extra charge.
Complete with a set of batteries. Pictures below. Two videos of it here:
Warm startup:
Under static 5.4kw load:
Batteries shown in the videos are not what are included (black batteries in photos are). Happy to field questions. Can ship anywhere a common carrier goes, but always prefer to deal local. Reach out here or direct. 413-224-8190. shtf.litd@gmail.com
78202875_423820644975917_3179827081097773056_n.jpg75627616_423820638309251_9191481522429886464_n.jpg20200125_093754.jpg20200125_093801.jpg
