2002 FMTV Air relay valve with fittings
Steel Soldiers is supported by:
shoeitime
Texas
Looking for the air relay valve and related brass fittings (elbows , reducers, etc) for a 2002 M1083 6x6. It's a Haldex seven port unit, mounts below anti compounding valve on frame cross brace behind rear axle. Ours has electronic ABS, so earlier model valves will not work.. I do not have any pictures of the valve as ours was removed long ago.. Key thing is that all lines that connect to this valve are hard nylon lines with compression fittings... Please let us know. Thanks
