2012 F450 Hauling 32,000 lbs. (5 TON)GVWR=44,500
decodeme2
-3
Lothian maryland
Hey guys,
If you need a 5 ton or lighter equipment hauled, My son or I can do it.
We do have a 16500 lb winch for hard to move items.
We do this part time, so we like to stay within 500 miles, But.....
Kevin..
ps, dont pm me..i dont check it that often..
decodeme@verizon.net
Yes its all legal. We stop at all the DOT stations.
Located near Ft.Meade,
we charge $3.00 a loaded mile.
Check out our inventory. We haul for our customers too!
maddawg308
723
Front Royal, VA
Uh, wow. I just hope the trailer brakes are feeling their oats when you have to haul a 5-ton. Just...don't try hauling any 5-ton wreckers, please? I don't want to read about you in the paper.
1,168
I'm kinda looking for a new trailer. I just looked for Load Max trailers and I only see an HD gooseneck up to GVWR 22000 lbs. And the trailer weighs about 6000lbs, so max load cap is only about 16000 lbs. Was your custom built? What model is yours? Did you buy new from a dealer(could you tell me the dealer name, if so?)?
tie6044
42
Blaine, MN
If your trailer is rated for 24,000 lbs that means the load PLUS the trailer can only equal 24K. I'd guess the trailer weighs close to 7K so that leaves 17K to put on the trailer. Unless your trailer is rated differently than most. Just my 2cents
Dangit doghead you edited while I was typing!
decodeme2
-3
Lothian maryland
Load Max 24000 lb with 2 12000lb axles. The truck has be upgraded with 19" michelin G rated tires, 5000lb each. Also subtract the goose neck weight, i prefer a 30 / 70% mix on the load. The truck can carry up to 10,000 lbs on the goose neck easily. Airbags are in the near furture. The trailer model is a Load Trail , 32' GN. LO-Pro. Call Cox trailer sales. (301)599-6285 located in Maryland. cost about 11k. It has awsome brakes too!.
We watch our axel weight, we scale out our loads if we think we are over axel, and move the load forward or back to get it perfect. Picking up a M818 soon...Should be interesting.
Kevin..
ps, Load trail on the title. load max on the trailer..go figure. Correct vin. Must be the same.
1,168
Is there a GVWR sticker on the trailer? What does it say?
I'm only interested in the trailer capacity. I would be towing with a heavier truck yet. I would like to have over 20000 lb load cap. I still don't see how your trailer can be that high.
GVWR = load + trailer. Nothing else.
GCWR = truck + trailer + load.
GAWR = actual load on axles
Here's the sticker that should be on your trailer(adjust for 12K axles).
Bighurt
46
Minot, ND
Legally that trailer is over-loaded, best of luck when you run into a finicky scale clerk.
GVWR is 24k including the MT weight of trailer. Another note is Load trail uses safety chains rated at 26400. Your weight of 5 ton and trailer exceeds that number, so at least in a hitch failure you'll risk others lives and not just your own.
And people criticize why the government is beginning to regulate more than HDT's in use. I see it all the time in the RV industry, 1/2 ton's towing monster rv's, grandpa's triple axle bus, you name it. Common sense is gone, the people have forced the government to regulate since the people can't.
Doghead Diamond C makes a triple 12k axle Gooseneck and makes a good trailer, although I don't like their spare mount. They can also throw 15k axles under one as a custom build, if I were to have a custom trailer built, I'd call them. As for the other companies, I'd call M920, he's worked a welding outfit before and can attest to some other trailers manufactures issues.
:beer:
1,168
Just found the spec for the coupler on that Load Max trailer, 24000lb max.
porkysplace
1,485
mid- michigan
It looks like the load in the pictures in post#1 exceeds trailer capcity by at least 30% , so I would have to say pretty unsafe and expensive if caught by D.O.T.
1,168
Do they fine you by % of overload, or by # over?
