3116, 3126, c7 Ac compressor?
ramdough
1,727
Austin, Texas
Which engines share brackets and pulleys for the air conditioner compressor?
I am assuming the 3116 and 3126 use the same brackets and pulleys.....even if it has a serpentine belt on the 3126. Does the C7 share the same brackets, pulleys and compressor for air conditioning?
Am I right? Wrong?
Thanks!
Third From Texas
6,327
Corpus Christi Texas
I was told that they use the same bracket, but having owned a '98 w/3116 that had AC (driver-side mounting bracket) and now own a '08 w/C7 I do not see how the bracket from my old truck would work. I was even going to pull it to fab a replica.
I seem to recall Scott Dewitt who sellsthe brackets (or used to) say they were interchangeable. And he does have versions of each truck.
I have seen mention of a second bracket. It could be the C7 takes both or just the second one.
/shrug
m-35tom
220
eldersburg maryland
It is 2 pieces, both of the parts in your 2 pictures. Fits all engines as far as I know. The sand colored part goes down to the LF engine mount, The black part bolts to that and to the front of the timing cover. Belt tensioner bolts to the front of the black part where the nut is welded inside the web om right side of pic.
simp5782
Feo, Fuerte y Formal
9,259
Mason, TN
Would be alot easier and cheaper to reroute the intercooler pipe and move the alternator up and put the AC compressor in its normal place, where the alternator currently sits at. Lots of civilian brackets in the junkyard with the serpentine setups for the 3116 anyway
There are also pedestal brackets for civilian alternators and compressors that are common CAT # 211 7876 for the alternator and the AC compressor sits above it. This can be done on the 3116 or 3126.
Lots of variants of brackets to use.
You can even use the bracket found in the MTVR Ac kit.
The kit for a serpentine crank, seals, with the dampener and adapter for the fan clutch is available brand new for $400 .
Third From Texas
6,327
Well that clarifies it then, I appreciate it. Looking at the image from the front I see now why I thought my old truck only had the one.
