4 ways activate electric trailer brakes
sarge62
Wyoming, DE
I have an m1008 that I removed the military plug and installed the 7 round civilian plug. When I use the 4 way flashers the electric trailer brakes activate. I would really like to be able t use the 4 ways when climbing hills and this truck has a hard enough time climbing with a load at altitude without the trailer brakes comming on. Does anyone know of a diagram or a solution?
porkysplace
1,485
mid- michigan
Most newer controlers have the diode built in. but you should be able to put one in the wire from the controler to brake light switch to solve the problem . Unless there is a issue in how he converted the mil plug to civy . The easist test would be to unhook the wire to the brake light switch and see if the prolem persists , if it does the problem is in the plug conversion or trailer wiring .
sarge62
Wyoming, DE
It is hooked up at the brake light switch. I will disconnect it and see if the problem persists. I am currently driving across the country and getting ready to go over the Eisenhower pass/tunnel. If nothing else I will turn the 4 ways on in the car that is on the trailer and finish this when i get back.
I disconnected the 6 pin flat on the truck frame and with the brakes on there are 2 wires that have 12v. One yellow and one green(?). They are the second ones in on each side of this flat 6 pin frame mounted weather pack connector.
1,168
Mine did the same thing. I had an extra toggle switch with me, so I put it between the brake light input to the controller. Now, on a hill, I reach down and turn it off if I need the 4 ways.
A diode is the correct fix.
aaron379
junction city ky
To bad you don't have a third brake light.... you could hook it up to that.... the 4 ways are the bright side of the bulb as are the brake lights so its back feeding in to your controller so you could put a toggle on later but for now I wouldn't use your flashers
1,168
I don't know what the specs are for that one.
Honestly, I'd just order one from the link I put up. I have placed several orders with them and I am always impressed with their rapid delivery and low prices.
