CT AN/VSS-3 Xenon arc tank searchlight
Steel Soldiers is supported by:
Suprman
21
Stratford/Connecticut
VSS3 searchlight. With control box and cable that goes between the control box and the light. Dont have any main power cables I have the connector part number you can make your own. This light runs good off a truck slave port. 24 volt DC and it takes around 75 amps to start it and 60 running amps. Pencil beam and it has a IR filter you can put over the beam. Good working condition but it needs to be cleaned inside and out from sitting. PRICE 1000 firm plus shipping or local pickup. The light is around 70lbs the control box and cable around 40lbs. Best contact will atpawnking dotcom
