Blown Cummins NHC 250 motor - Looking for replacement
Steel Soldiers is supported by:
gjmcginn
Okeechobee, FL
Loaned my M929A1 to a friend & the motor was blown driving down the highway. Cummins NHC 250. Need a reasonable replacement.
Greg
772-263-3979
Okeechobee, FL
gjmcginn
Okeechobee, FL
Fix it, unless it spun a bearing, easy to repair. What "blew"?
I need to talk with the mechanic & find out specifically. My buddy had it hauled to a place & so he was the point of contact. They initially thought it might be no big deal ...then apparently dug into it some & said time to start over.
WillWagner
Loose Nut
183
Monrovia, Ca.
Careful, alot of "mechanics" will blow smoke up your....tailpipe. Find out the particulars. Like I said other than a spun bearing...or a hole in the block, 855s are repairable in chassis.
Tracer
816
Hawthorne, NV.
If you decide to go with a replacement engine. Call White Owl Parts Co., they have Military rebuilt Cummins 855 & Take Out engines available. They're up the road from you in North Carolina. 252-522-2586 Nice folks, check out their web site.
