Bulb Voltage interchange Chart (6V 12V 24V, for trailers and trucks)
datsunaholic
Tacoma, WA
Just be advised that the standard 12V 1157 2-element bulb and the listed 1662 24V 2-element bulb are actually wired opposite. I had to do some wire swapping to make that exchange work. Haven't found a TRUE 24V "1157" replacement.
ida34
36
Dexter, MI
I got the 1662 and filed off one of the pins on the side. This allowed me to put it in the socket backward so the lights worked without rewiring. Worked just fine.
OPCOM
29
Dallas, Texas
http://old.steelsoldiers.com/index.php?module=pagesetter&func=viewpub&tid=3&pid=45
It is a beter copy too.
Thanks for the note about the 1157 vs 1662. I wonder what idiot designed them that way?
Since I will be wiring an M105 pigtail in, I can take that into account and swap the wires (might have to add a pair of diodes between the 12V tail light source and each 12V tail light filament depending on the trailer's existing civvy harness).
- and while we are at it, in the same section, Lights Bulb NSN from PS 670:
http://old.steelsoldiers.com/index.php?module=pagesetter&func=viewpub&tid=3&pid=77
OPCOM
29
Dallas, Texas
Job done. It was simplest to use two surplus "bridge rectifiers" taken from a scrap power supply to route the voltages properly. Works perfectly and no annoying wire-swapping required.
The user has only to install the right bulbs depending on if it will be towed by the 12V civilian vehicle or the 24V military vehicle. There are two pigtails. One fits the M35 and one fits the pickup truck. Instructions are attached so that anyone can do this pretty easily. The connections and diodes can be stuffed in a plastic or metal box if necessary.
The attached file has been submitted to the Technical Articles section of the Resources.
