dikwks
- 1
- 18
- Suffolk VA
I recently put 11.00X20 radials on the deuce. It rides smoother for sure, but has the same symptoms that others have noted: a poor return to center and a squirrely feel to the steering. The steering system is tight so it's not a parts issue. I'm pretty sure it is a caster problem. As in there ain't enough.
I've been looking through the threads about caster changes, but can't find specific info with regard to how much change is needed. The amount of change on the spring perch modification by gringeltaube calls out a 2.5º, someone else got a 3.5º shim, and someone else had posted a picture of a 4º shim. I would prefer not to alter the spring perch as it would be a permanent modification. Adding a wedge would be my first choice.
So, my questions are: 1. How much change have others made? 2. What shims did you use? 3. Where did you get them? 4.The picture I found shows a shim that is 2.5 inches wide and 5" long, but the contact patch of the perch to the spring is 2.5" by 6.5" long. Is 5" long enough? And last, 5. Was your locator pin in the spring pack still long enough?
Looking forward to hearing from everyone, Dick.
