Correct vent window seals!
GUYS, I purchased one piece Precision seals. Dont waste your time a pita! I found two piece precision seals #VWK1110 81 A OR VWR81. Its a perfect fit on my m1008 . Remove the window unit, drill out pivot rivit, remove bottom nut ,spring and washers, take out glass, drill out three rivits to remove vent frame from window rail, Sit down and push in seal into grove ,soapy water helps, put back together in reverse, install new pop riverts where you drilled and I used a 8-32 x 1/2 screw and locknut on pivot instead of a rivit. you can gett the right rivit and tool from LMC. Hope this helps ,its been a long search and I found on fleabay ,under 50 bucks for both sides shipping included.
Grega
St. Paul Nebraska.
I need to replace my seals. On an auction site it says the 2 piece is for 85 and older and the one piece for 86 to 91. On my 1986 M1009 could I use the 2 piece, or is there much differance between the two that I have to use one or the other. THANKS
Grega
St. Paul Nebraska.
Thanks for the info, will look for some 2 piece seals. These are the last seals pieces that I have to replace. Ive been somewhat reluntant because it looks like it could be a PITA. Thanks everyone for the input.
JSF01
Newport News, VA
Fid that come with the bracket for the glass? I ask because the other day when I went to open the vent window the metal rod part of the bracket snaped.
iacucv
Spencer, IA
I might be doing this, but might try to band aid it in the mean time by tightening up the vent window latch on pass side. Can anyone tell me how to tighten it or point me to a thread that could help?
CUCV85
central/ny
band aid
Use a washer or two in between the turn latch.
Clear silicone the h e double hockey sticks out of it.
There I fixed it.
"Band Aid"
[thumbzup]
sschaefer3
Tempe, AZ
I found the pivot rivet on LMC but I can not locate the tool for the rivet. Can someone help me out and point me in the right direction.
I used the Precision Seals as the LMC ones were wrong. The rivet is the last thing left.
Thanks!
