Leece-Neville starter on my 1971 M35A2 with LDT-465-1D needed replaced. Local starter shops would not rebuild it because they do not rebuild Leece-Neville. They wanted to sell me a reman Delco for $250 with 6 month warranty. They would not take the Leece for the core charge because they do not rebuild Leece. Called Delco-Remy tech, gave them the specs off my Leece starter and found a brand new new model Delco that will fit. It is aluminum, weighs about 33 lbs and has an indexable mounting flange with no nose cone. I called around and the best price I found was $328 out the door from Glen at
http://www.diesel-plus.com/home.cfm I bought it, had to rotate the mounting flange to clear some items, installed it and it has worked great so far.
Model 39MT (there are several part #'s but only one that will replace the multifuel 12 tooth that I have)
Delco Remy Part #: 8200435 drawing is attached
Warranty: 3 years
