allenhillview
- 3
- 0
- Jonesborough, TN.
Just finished seals in both output shafts in TC, filled with new fluid twice, first time I did rear seal then front shaft looked moist so I ordered new ORD mounts and replaced front seal at this time, requiring a second fluid refill.
I can now hear a wind sounding noise at different times, very faint but for sure there.
Is it the new fluid?, Has the fluid made it appear tightened up a bit? With the new mounts can it be causing me to hear the chain turning?, doesn't do it all the time just every few seconds, doesn't seem to get louder as speed increases, just the same pitch all the time.
Balanced drive shaft before, so this did not start till I did the mounts and seals.
Should I have replaced bushing, it did not have wear marks on shaft yoke nor was the bushing wore in obscure manner, truck is 28,000 miles?
No vibration..no clunking..etc.
I will appreciate any input and passed encounters.
