TX Envinrude Outboard
Steel Soldiers is supported by:
thtrev2001
San Antonio, Tx
This is a 2009 55 hp MFE (multi fuel engine) outboard made by envinrude for the military. This outboard was only offered to the military. It was designed for a small special forces zodiac, it can be submerged and then floated again, drained then started. It can use kerosene, jet fuel or gasoline. It is also equipped with a jet pump, no exposed propeller.
this motor is extremely clean and obviously low hours. It starts on the first pull and everything works as it is supposed to ( Although I have never submerged it ). It does have some scratches on the left side of the cowling.outboard side scratch.jpeg
It comes with a clear title
$6500image8.jpegimage1.jpegimage5.jpegoutboard motor side.jpegoutboard tag.jpegoutboard tiller.jpegimage4.jpegimage3.jpeg
