Ether Starting Fluid Canister
D Foster
Franklinville, New Jersey
Hello, I found that my Ether Canister was empty and purchased a new Ether can through Napa Auto Parts. Does anyone know if the threads are different than the military stock number as I am having trouble screwing it down. Thanks for your help. Dennis
D Foster
Ether Canister
They make canisters with a couple different threads , you need to compare to the old canister .
I know exactly what you are saying but unfortunately it was trash day and I threw the old canister away. I had no idea there would be different threads? I assumed it was going to be same threads and just screw on. Live and Learn! Thanks, Dennis
D Foster
D Foster
UPDATE/FINISHED! I found out the Napa Either Cylinder (#33118) does have the correct threads to fit the M1078. Even though my old empty cylinder screwed off easily the threaded base was not lined up well. I had to actually loosen the lower mounting bracket to allow the base to line up with my new Napa cylinder and it screwed right on. Problem solved and hope this may help the next guy. Thanks for all the replies.
