Generator 2 light stays on
Oldsouthernboy
Jacksonville, al
My Generator 2 light stays on even when not running. I have been trying to figure this out but lost on this. I have just cleaned all the contacts on the circuit board and light holders, Cleaned the connectors on the both alternators, made sure that the grounds were clean, new belts on generators and checked for strech, Voltmeter stays in the green when running or idle. all the terminal studs cleaned and tightened. I am lost may be something so simple and in my face I am overlooking, but baffled.
para 3
11
france
Hello from France
check the relay of generator 2 (under the dashboard)
“GEN 2“ LIGHT REMAINS ON WITH KEY IN “OFF” POSITION
Step 1. Remove generator 2 relay.
If light goes out, replace relay.
If light remains on, trace circuit through brown/red lead to “GEN 2“ light in
instrument panel.
good luck
dougco1
548
Cooperstown NY
Hello from France
instrument panel.
good luck
11 year old post; I assume the op has resolved the issue by now.
