KS Heavy Copper Cable and Jumper Cables
Steel Soldiers is supported by:
98G
Former SSG
332
AZ/KS/MO/OK, varies by the day...
And 2 pieces of 3/0 stranded copper cable. Each piece is 25' long. All ends terminate in a 5/16" lug, hydraulic crimp @ 16 tons and then heat shrink applied.
Condition is new.
I was going to make slave cables out of it but my clamps are incompatible with the lugs. I'd rather sell it than cut the lugs off.
This would be a good choice to power high amperage loads, like an electric winch.
$80 each or $160 for both, shipped CONUS.
98G
Former SSG
332
These two SOLD
Two pairs of #1 AWG jumper cables-
The first set is intended to be a direct duplicate of Associated Equipment part number 6161. I used the same 800amp clamps with the spring anti-kink device and pure copper #1 awg cable. 15' long. Cable ties every few feet. Theirs are $280. Mine are $200 shipped.
The second set is intended to be an improvement over Associated Equipment part number 6161. Instead of their 800amp clamps , I used nice heavy brass 1000amp clamps. These use the same copper #1 awg cable and are also zip tied every few feet. Also 15 feet long. $200 shipped.
The pictures are going to all post together. I presume you can tell them apart.
98G
Former SSG
332
Two more sets of extreme heavy duty jumper cables.
Set #1 - twenty seven foot long cables made from 3/0 cable. Lots of reach and more ampacity than issue slave cables. $380
Set #2 - eighteen feet long and made from 4/0 cable. Twice the copper as issue slave cables. $350.
Both sets have dual powered brass jaws (compare to goodall part number 14-950). All the crimps are hydraulic @ 16 tons and then heatshrink is applied.
The ones pictured on the wrecker are 3/0. The ones pictured on the M998 are 4/0.
Local pickup available between Scottsbluff NE and Washington KS or I can ship them.
