Id this generator
truck0590
Manassas, VA
What is one of these worth? Owner wants to get rid of it, but I don't even know if it works. The door in pic 1, with the gauges, is bent 90 degrees. Anything I could check on it?
Truck
tmbrwolf
Manhattan, Kansas
It could be an MEP-018 60Hz 10 KW or the MEP-023 400HZ 10KW, both look identical, 60HZ would have some use as such more valuable, 400HZ would be next to useless, unless you happen to have a field radar unit!
truck0590
Manassas, VA
Looked again today and after checking the TMs to see how to id. It is definitely a MEP-018. What kind of value would it have, since it is usable for residential power?
Truck
1,122
When you weigh the value and what you are willing to pay, consider that according to the TM it uses 2.25 gallons per hour.
Michael
9
Fulton, MS
A good working one should be worth about $1000. 2 of unknown condition on their trailer would bring about 1500 on GL several years ago when the government was dumping all gas equipment. They are very loud as well as gas hogs.
