KEYED BATTERY CUTOFF FOR THE DEUCE
Steel Soldiers is supported by:
Those Military Guys
Rancho Cucamonga, CA
KEYED BATTERY CUTOFF FOR THE DEUCE- $79
This kit is for deuce trucks with the batteries under the passenger door the cables have been designed to fit the DEUCE so you can mount the switch close to the driver for easy reach for the driver.
Now you can have peace-of-mind when you leave your truck unattended. With this cutoff switch and a pair of our LOCKING DOOR HANDLES, your military truck will be just about as secure as you could hope for. The keyed switch is rated at 180 continuous amps and will handle a 1000 amp surge. The cables are heavy duty 2/0 welding cable.
Installation is straightforward, and is easily accomplished with simple hand tools and easy-to-follow instructions.​
Place a order:
TMG UNLIMITED LLC
909-703-1400
thosemilitaryguys.com
