M 109 "Blowing Smoke"
mcalpin81
Braxton,MS
Just acquired a 1972 M109. The truck is blowing a ton of black smoke and I have been advised the problem would be in the injection pump. What is the proper way to lessen the amount of fuel be sent to the injectors so to stop the tons of smoke?
73m819
314
gainesville, ga.
Why is the black smoke bad., The truck is calling for power
1,168
Is the air filter dirty?
Does the truck have a turbo?
glcaines
2,399
Hiawassee, Georgia
How much black smoke is the truck exhaustng? These trucks all normally blow black smoke. You need to post a short video.
Wolf.Dose
9
Boehl-Iggelheim, Germany
Black smoke is inpropper burnd diesel fuel and therefore a waste of energie and money.
Fuel injector pump instalation and propper timing tune up is described in TM 9-2815-210-34 - 2, chapter 5-32 to 5-36, page 5-169 to 5-193.
Wolf
mcalpin81
Braxton,MS
I can try to do that, picture is worth a thousand words. Just seems to be excessive, not what I've normally seen on other trucks. Hey thanks, gonna get to work on a video.
Katahdin
23
Scarborough, ME
My 109 does not blow much smoke, its turbo'd and the air filter is clean. I haven't made any fuel modifications after getting it from GL.
1,168
HAs the IP been tampered with?
There should be 2 lead/wire seals on the adjustment points.
