M1008 glow plugs don’t stay on
Kool-Aid Kid
Ionia
Glow plugs only power up for a split second. I have installed a new controller card and relay turn the key on and you can hear the relay cycling but it will only power up the glow plugs for a split second at a time any help would be appreciated
richingalveston
120
galveston/Texas
the temp sending unit to the glow plug card is probably bad. your card may be working properly but if the temp sending unit (which I believe is in the back of the passenger side head) is bad, the glow plug card thinks your engine is already warm.
check the sending unit. I think there is a method for testing this sensor in the TM's but do not know for sure.
