M1009 glow plug problem. ..need help
irishvin
Wappingers Falls, NY
My m1009 glow plug light wont come on unless I trun the key almost to were the starter kicks in ...this started happening after I replaced the gp relay.... idk what I did wrong I put all the wires back the way they came just need sum help thanks
Warthog
227
OKC, OK
Have you adjusted the ignition switch on top of the steering column?
Warthog
227
OKC, OK
From you description, the switch is out of adjustment. The TM has a step-by-step. TM 9-2320-289-34, Chapter 4-13
Sounds like it was just a coindidence that it happened when the relay was replaced.
Just for grins, post a pic of the new relay and the wires.
cpf240
Free in Northern Idaho
Replacing the GP relay shouldn't be related to the position of the ignition switch.
Do the other lights, GEN, Oil, Seat Belt, etc, come on before the Wait light when turning the ignition switch? If they all come on at about the same position in the rotation of the ignition switch cylinder, then I'd suspect an adjustment of the ignition switches or replacement may be in order. The ignition cylinder is really just driving a rod that moves the actual switch that is lower on the column.
Might want to study the wiring diagram to see if the GP system gets activated from a different portion of the ignition switch then the rest of the idiot lights, etc.
