M1075 A1 Planetary Hub
ev2bfree
-4
Richmond, VA
I have a 2011 M1075 A1 Oshkosh 10X10 PLS. I need either parts for or an entire Hub Assembly. There raining nut for the main bearing come off and the hub shifted outward and blew out the main bearing sending bits all through the Hub. The CV Boot also tore open on the other side of the same axel. See Photos below (I have more);
Code:
mUDm12fzTterzGNpPHslFQ.jpgsUe1oio2QOON7rw+cofckw.jpg56823606707__7B05AA5A-8B59-42C2-90BD-1E37DFE3259A.jpgIMG_4679.jpg
ev2bfree
-4
Richmond, VA
Does anyone have a source on a TM for the A1 variant of the M1075? I have all of the TM's for the A0, but the stuff I am working on is totally different on this newer version. I can see already that I need a much larger socket for the main bearing retaining ring. I have one for the older model, but it is way to small
